Seiko
BUT, the great thing about Seiko is they have released thousands of not tens of thousands of different models from plain to funky and everything in between. So plenty for everyone without resorting to all having the same models as each other.
Check out the Vanac range or some of the Lord Matics.
This is mine [emoji4]
The big factor Johnnie is your budget. You can pick up a decent Seiko automatic for £20 or the most I have seen is just over £20k (which was a well known collector buying a model lots of people didn't believe existed in real life from Japan). I'm much nearer the first number unfortunately!
I'd suggest that you visit instagram, type #seiko or #seikoaddict or #seikolife, start scrolling and make notes and start doing research on the ones that speak to you.
But my main advice would be: Run! And don't look back! Once you start on the Seiko habit it is very addictive...
Well if you want to start budget, SKX007 or SKX009 (the 009 is the pepsi bezel one) which has a 7S26 movement. Or if you go a bit more you can get a 777 which is hacking and hand wind and just a better watch. Or you can stretch to turtles, or to a marine master, or the beautiful SLA017 which is the modern ltd edition interpretation of the 62MAS, or you can go down the rabbit hole that is vintage - and let's leave quartz out of it for now as that's a whole other list... even if you just restrict to divers you can spend pretty much whatever you have!
Whatever you get, post pics, I do love a Seiko!
Hi Pip. I am only just starting to realise the depth and breadth of the Seiko range, by goggling the above suggestions I am looking at watches I didn't know existed, amazingly some for very little money and also for a lot more.
On December 21, 2017 at 9:34 AM, rogart63 said:
6309-7040/6138-8020 and if no money is the limit 6159-7000 . But that is something that change from time to time.
I can agree with these choices for starters although I like the 6309 - 7049 a bit more then the 6309 - 7040 . A little wider cushion .
Both classic beauties .
6309 - 7040….
5a51b04daec9c_ScreenShot2018-01-06at7_29_14PM.thumb.png.0a0a4fd386ef56219e7030c255e4b322.png
5a51b07b9c47b_ScreenShot2018-01-06at7_28_46PM.thumb.png.9d4ef43b440e05bf74799d674b8c0399.png
6309 - 7049…..
5a51b1a93ead0_ScreenShot2018-01-06at7_34_50PM.png.b00bf5b56e3b45cda6b94aefc5a6b697.png
5a51b1cf73e2f_ScreenShot2018-01-06at7_33_47PM.png.7b1f40d825c5088fcc2ad8953665c9d9.png
6309-7040, 6105-8110 and 6138-0011
i guess I am biaised as I  happen to own all three (and a few more) but they are real classics.
if i could add to the list it would be the 6138-8020, panda dial, i have been looking for a nice original one for a while
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
