My Workbench
GeorgeC
59 minutes ago, GeorgeC said:
At ~2:40 position, the repair benches they are using looks ideal to me  not sure where to source one yet though.
Bergeon sells them, even motorized ones to adjust height. Their price is high enough to scare away most hobbyists, so people gets what most looks like the business. In the US, Ofrei has something.
You need to make sure your posture is correct otherwise it can cause all sorts of damage to your neck, spine and goodness knows what. I suffer with spondylitis, Im 63 and I have neckwear of a person who is in there 90’s.
Need to exercise along with watchmaking:)
I have the same configuration. For example, here is my boley lathe on my desk. I made a Hampton balance staff yesterday. it took me a year............. well, only actually a day.ed2c743639313d6fc71ae730450738f6.jpg&key=fe43e93464dd2523fcb3e57b29d07806ff9089d652dc943be91e7e00cdd94114
Or as they say, "it took me a year to make it in one day"
Yesterday 2017, today 2018= 1 year and one day as well.
I completely misunderstood your comment, I thought you started the project a year ago in Jan-feb and forgot about it or something similar and you finished recently. xD
32 minutes ago, vinn3 said:
for sit and work jobs;   excercize daily.   this will cure most pain {except old age}.  vin
Absolutely. Glad you threw that in.  Promotes calm, strength, balance and circulatory needs to stave off aging. Well worth the time investment.
Steady, consistent is the key.
Not to take this thread to aside but, if I am not running one day, I use an app called Seven (no affiliation) that provides seven minutes of various calesthentics without need for equipment. Can do repeatable cycles for longer workout.
Happy New Year everyone.
Nothing to put aside, posture and ergonomics in general are part of the whole hobby/profession. Thanks for the advise.
On ‎12‎/‎20‎/‎2017 at 4:44 AM, oldhippy said:
Some time ago members posted photos of their workbenches. If you would like to post your photos just go ahead. There’s no designated thread.
most books on watch repair will describe [ a proper bench].
amazing! i have seen those tool handles on "engraving tools".  the flat spot was for listing size.
    • I am pretty sure the correct practice to insert a tensioned crystal is to use a crystal press - although I always hate doing it as one slip and the crystal can skid across your dial, this happened to me on a Tissot, mangled all the hands and scratched the dial down to bare metal. I much prefer to remove the bezel and install the crystal into the bezel and then the bezel back onto the watch, not sure if this is an option for you?
    • Well, Geiger counter showed up today and the dial and/or hands were extremely radioactive, reading quickly spiked from a baseline of 10-20 cpm to 100 and was still rising when I removed it. Trashed the whole thing. Thankfully nothing else outside the components was registering - work surface, tools, the paper I had used to clean off some components....    And now I have a Geiger counter to use to  check practice watches BEFORE disassembly
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
