I began stripping my first watch this morning but with my 6yr old insisting on bothering me I didn't get too far.
If anyone can help me label the parts or provide tips please feel free to chip in.
Thanks to Marks video on subject I started with the calendar side first.
Here i go with the the first few parts.
I'm looking out for springs pinging from every coverplate I remove.
I'm a bit concerned about removing a part from one side and having parts from the other side drop off un-noticed, can this be a problem?
When I started again two cogs fell out unexpectedly - thankfully i have the photos to help find where they came from.
Next I removed the plate near the crown, as expected i found a loaded spring before it had the chance to spring out
I've removed the screw and jewel from the above photo - I'm not sure I needed to do this.
I'd  like to apologise for the lack of correct terminology, I'll get there.
When I turn the movement over to work on the motion side two cogs and a small lever fall from the side I've just been working on.
After a brief panic, both cogs are back in place along with two levers, spring and plate, all screwed back into place.
You're doing great. As long as you have the parts, you're all set. The small lever is the set lever. The 2 cogs are the winding pinion and the clutch; they probably fell out when you pulled the stem. The lever (clutch lever I think) is attached to a screw that you get to from motion side. it doesn't unscrew all the way, just a couple of turns should release the lever.
This is all from a newbie knowledge, I hope someone can confirm all this :)
Edited by frenchie
Well done Phil, it's a great feeling when you sort out your first watch and everything works at the end of it. Your photographs are excellent, they're as good as I've seen anywhere!
Thanks for those labels for the parts. The larger lever (clutch) was just on a peg, it just needed a bit more convincing to come off.
In step 5, the 'small cog' has one side which is 'chamfered' and one side without... ie one side of the gear teeth is slightly rounded... look at it edge on..
Your doing well... if you're a beginner..  unless you have a very 'clean' room, when assembling springs do it iside a plastic bag... saves a lot of time.
Oh.. and was the watch working to begin with?
Anil
Excellent work, keep it up! By the way, I always remove the balance wheel first so I don't damage it accidentally while handling the movement. I place it "wheel down" in a separate, plastic box with lid. Hope it helps.
Hi Anil, the rounded teeth, what would it be the correct orientation, up or down? Does it has to do with how it engages another wheel/pinion? Thank you in advance.
Edited by bobm12
Anil
I'll have a look at the small cog tonight and make sure it goes back the correct way.
Yes, I'm a beginner to this type of work. Normally I'm a bit too impatient and would pull things apart in the belief I'd remember where they went when the time came to put them back together.
The watch was working but stopping intermittently. My aim of this first try is to take it apart and reassemble. I'm not too concerned about replacing the main spring, cleaning and oiling, just getting it back together in one piece with it ticking.
I'll probably be starting the movement side tonight so I'll follow your lead, as soon as I work out which bit is the balance wheel :)
Thanks guys these links are helping with the naming.
In step 8 I remove a cover from the movement side and the task ahead becomes apparent.
Looking at what is underneath it looks like I have to remove the crown and ratchet wheel first.
But there's a problem, I can't get the crown screw loosened. It seems stuck tight and I'm worried about applying too much force.
Remove all residual spring tension first. To do this turn the crown as if to wind it then with a small screwdriver or pegwood ease the click out of engagement with the ratchet wheel. Now let the crown gently spin between your thumb and finger until it stops.
I didn't say to unscrew it Phil. The click (small lever) only has to be gently pushed out of engagement with the ratchet wheel.
You turned the crown wheel screw to the left, yes? It is a left-hand screw. And of course you do this after releasing the mainspring tension so that everything wouldn't fly away.
Crown wheel screw is often a left hand thread. Unscrew it as if you were tightening it. go easy on these two screws as they can shear very easily......
Thanks guys - I've removed the crown wheel screw without snapping it :)
I took out the crown, ratchet wheel and click mechanism but forgot to take a photo of the click mechanism while it was in place.
I should be able to work out how to get it back together the right way.
I'm amazed how small and intricate the center and adjacent wheels are. It's not surprising it was recommend I buy a good set of tweezers.
What I think is the 3rd wheel is carefully removed next
I hope I have all the parts labelled correctly - let me know if I've made a mistake please.
Big thanks to everyone who's commented and helped me get this far.
Phil,
You are doing great and the pictures are fantastic. As others have said the screw is reverse threaded (so it does not unwind itself when the watch is wound up). Be gentle with this screw as the head can break off quite easily.
Good luck and keep us updated :)
Great job PhilB, for what you are saying I suppose you will be putting it all together quite soon! Remember to be extra careful with the balance wheel!
PS. I can't see your new pictures until I get to my home computer!!! I bet they are good like all the other ones you posted.
Edited by bobm12
    • The other thing that makes pallet forks like this interesting is or some of these interesting it when they're not level they don't fit well on the pallet fork warming tool and melting to shellac becomes a challenge. One of things you want to do when working on vintage pocket watches is accumulate broken pocket watches and swiped the jewels from them. Because as you're finding out the vintage jewels were probably not made out of Sapphire there are made out a Garnet and Garnet doesn't seem to hold up as well as shellac. Then the last little part about stones pointing in different directions doesn't make sense? There's always a left stone a right stone angles are different and they both have to be in the same direction. Although I once had a pocket watch command were somebody put one of the stones in backwards and surprisingly the watch ran. Then on some watches I done this with 12 size watches I've been able to swipe pallet stones from other 12 size not even the same company because they may have purchased or stones although Elgin I know at some point in time did make their own tools and had a separate section of the factory that made diamond grinding compound for all their lap and during work. Then when the company got liquidated the diamond division was sold the somebody else in the last I knew it was still running out there but not of course under the Elgin name. Still making diamond grinding compound.   From the 1915 parts catalog you can see all 18 and 16 size pallet stones are basically identical. The difference is what they're made out of and one of them that they didn't policy side in stone probably in a seven jewel watch no one would ever see that anyway. Then you have a new or the old style determines its thickness and you would have of course right and left Then I'm attaching a PDF of Elgin escapement terminology is it is nice drawing to show you the difference between the left and right stones. Elgin watch company Escapement Terminology.PDF
    • The roller table is supposed to be held on by friction. If there is shellac under the roller table it might indicate that an improper repair had occurred prior to this as it would not be held in place with shellac. Sometimes overenthusiastic people re-shellacking the roller jewel will get shellac where it's not supposed to be. Then the picture of your roller it looks kind of damage? It doesn't quite look right it looks like somebody held with a pair of pliers or something? Then your balance wheel has limited quantity of screws? Not necessarily a problem but an indication of perhaps with the other things a prior bad repair perhaps as a guess.
    • Quartz watches like mechanical watches need to be serviced from time to time. In other words the lubrication with time we'll go bad and the watch Will not run or will not run very well in other words oh be slow because the gears are no longer turning properly due to bad lubrication. Then other things bad for quartz watches basically anything dust that normally wouldn't affect the mechanical watch will affect the quartz watch because the quartz geartrain has extremely little power. So looking at your movement up above more than likely you'd have to clean it and lubricated before the new circuit would work.
    • I be concerned if this roller table belongs !   Timegrapher will ask,  where did you get this roller table or balance staff from?   Regs
    • Hi Graham, Welcome aboard.
