Today I got this Omega Constellation I have never seen before, around late 70's? It has kind of octagonal shape and has a quartz movement with quicksetting. As the back is already damaged by the previous owner, I wonder how to open this one without further damaging it as I would like to know which caliber is inside. Appreciate your help guys.
It has a snap off case back. That means you have to pry it open. Do you have a case back knife ? You could also use a knife with a thin (but durable) blade that isn't sharp or pointy so that you won't damage the case.
Look for a small slot/space somewhere along the case back as that is where you should insert the knife. Unfortunately not all watches have that...
You can also try to use a rubber ball and rotate it around a bit to free it from potential gunk and afterwards pry it open but that won't always help.
Edited by Chopin
In addition: The minute hand is set by turning the crown as usual but the hour hand is set by pushing in the middle of the crown. The hand then will run forward.
thanks Chopin...there is no space whatsoever, I guess that explains all the scratches on the side of the caseback. I will give it a go with the squeezeeball, see if it turns a bit.
You can buff off the scratches. Just tape out the brushed part as that is more difficult to repair.
Edited by jdm
  • 2 months later...
Hi, i'm a total newbie here.
I have exactly the same watch, which my partner bought for me as a birthday present about 4 years ago now.
However, unfortunately i have never worn it because it isn't complete. He thought it would be quite easy to source a dial and hands for the 1330 and this watch case. To complete it.
But it has proven harder than we thought. Can you help in any way as to where i can get a dial for this watch, hands etc. i have tried many a dial that is the right size as the case however they are not compatible with the case.
I would love to be able to wear this watch. I love it so much.
Any help or advice would be gratefully received..
Many thanks in advance.
Welcome and good luck sourcing the parts.
You could send a message to
http://www.ofrei.com/page665.html
And ask availability.
Or if you are in the UK then try Cousinsuk.com
You will need to provide the case number which is inside the caseback - probably  395.0802 if the same as the watch above. Alternatively you could try one of these items from eBay which have case, dial and hands:
182937592182
162781970733
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
