Longines 291(?) help
Chopin
I have the opportunity to buy a lovely Longines watch but I'd like to know if this is an easy fix. Seller only says that a screw is missing from the oscillating weight and that that's why it's not installed on the movement.
I'm not sure how this one works and how it stays on the movement and I also feel like I see a screw on the weight in the picture. Could someone shed some light on this ? Should the weight have another component that goes into the slot or is just a screw necessary ?
There is a screw on the weight near the movement and I see it in the picture but I assume that's not what we're talking about...
Also, is this even a cal 291 or something else ?
Is the circle in the bag, around the weight, even part of all this ? Could it be some sort of a ring for the movement ? Doesn't seem like it...
Edited by Chopin
It is a calibre 291 the rotor sits on a post at the centre of the movement and the screw on the rotor is used to secure it to the post. It is probably the rotor post that has broken, these are listed as obsolete on the cousins web site, it is a common problem with this movement I dont know if any other supplier would hold this particular part. The ring looks like a tension ring from a watch crystal and is not a part of the movement such as a movement spacer ring as this one is held in place with clamps
Is this post a separate part that gets screwed/attached onto the movement and then you attach the weight or is it attached to the weight itself ?
It's most likely hard to find so only solution would be a donor movement...
Edited by Chopin
Yes the post is a separate part that is secured with two screws from the under side of the bridge, why not ask for clarification from the seller as to what part is missing or broken if its just one of the screws that holds the rotor post in place it should be easy enough to find a suitable one to use but if it is the post that broken then you will have trouble finding one as you say the way to go would be a donor movement but that may start to make the good price look a little less appealing
Seller doesn't seem knowledgeable. I got another picture from him. Is that the post ? Not the best picture sadly...
I think I can see a screw and a missing one... Am I wrong ? Do you have to detach it from the weight to install it onto the movement ? I see no other way...
Edited by Chopin
It's a real pity because looking the movement it is in really good condition apart from the screw or post has been broken. The 291 is obsolete so its up for sale.
No the post sits directly in the middle of the movement and is not part or the rotor itself. If the watch is very cheap I would take a punt and factor in the cost of a donor movement if its only slightly cheaper than a  runner walk away.
If it is just the post it should be possible to make one,  if you have a lathe that is !!!
So, basically, there should be another part between the movement and the rotor right ? I was hoping that the thing on the underside of the rotor might be it but I guess it's not... Wish I could find a schematic of the movement and see what that part looks like...
No lathe. Not that advanced I'm afraid...
Edited by Chopin
Is it this one below ? I keep finding it listed for other calibers so I guess it might be interchangeable... Very pricey sadly.
This part should replace the one marked axle by @wls1971 right ? I'm assuming you remove the top plate, install the new one, put the plate back and then screw it in place with those 2 screws and then the rotor... ?
I wonder if there's a chance that it might not be broken and it's just missing the screws...Only close up shot I have.
Edited by Chopin
25 minutes ago, rogart63 said:
Is the 290 post the same as the 291. I now where you can find one. Send me a PM and i can give you the contact.
Yes calibre 290 no date calibre 291 addition of date at either 12 o'clock or at 3 o'clock
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
