Today Zenith introduced a completly new kind of escapement consisting of only two high tech silicium parts.
http://www.zenith-watches.com/campaign/defy-lab/index.html
Here are two additional links (sorry, main article in german language, but some good pics):
https://www.luxify.de/weltpremiere-zenith-defy-lab/
https://player.vimeo.com/video/233528319
I didn't really make up my mind right now about that thing. On the one hand it's fantastic brain work and unbelievable performance for a mechanical watch. On the other hand...well...I don't know how to put it. With all this high tech computer-developed material and manufacturing it feels a little bit cold, without emotion and craftsmanship. What do you think?
Very interesting to be honest. I'm usually old school but as long as it's mechanic and not digital then it's fine in my book.
It sure does look weird and all but it also looks pretty fascinating. Zenith sure doesn't waste time...
There should be a patent about this, which would allow to understand it better. But I suspect the secretive Swiss do not allow online access or even search.
The only thing that I don't like is the fact that the watch is skeleton and you can see that chaotic shaking all day long. It would mess with my eyes if I stared at it long enough...
This could be a very interesting development for watch movement manufacturing. Zeneth suggests an accuracy of ± 0.5 seconds over 48 hours which is very impressive. However the issue I would have thought is the rate it runs. It has a staggering frequency of 108,000 vph. With this frequency will wear be an issue also how stable is it, can it take normal knocks & shocks watches do endure. I guess time will tell.
I don't like that either but if you look at the trend in contemporary Swiss haute horologerie most design are very bold and show off whatever they can invent in place of a dial. And I think this mov.t seen from the other side only shows wheels and not its main feature, so it was a kind of forced choice.
What an incredible piece of innovation!
It's quite inspiring to think that there are people capable and willing to think laterally and not be constrained by old tradition.  I'm sure that if some of the great horologists from the past were able to witness this, they too would be mire than slightly impressed.
I love it!
    • Yep…This makes perfect sense. With that large a gap in the serial numbers, they were almost certainly machined on different equipment, hence one should have no expectation of any cross-batch compatibility. I’ll revert to the original bridge. Regarding bending the bridge @nevenbekriev, I’ll give it a try, but I may have to buy some better calipers. My Vernier calipers are only accurate to 0.1mm. Not very accurate.
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
    • I would change the container to a thick walled brass one to start with. Looking at you screw pictures they don’t look shiny enough, really it’s best to do a black polish on them before trying. Also make sure once polished they are scrupulously clean, I dunk my experiments in acetone before bluing.   i think the thin walled stainless container to leach away the heat from the shavings, most successful bluing videos for example use thick walled brass to hold a good deep amount of shavings which acts as a better holder of heat.   Tom
