Watchmakers Lathe Or Mini Lathe
The back when new would have been the same colour as the rest of the case as you can see very dark gun metal is a very dark blue/black and would not be shiny. So unless the owner intends to match it how it would have been when new which I don't think it can. It should be left as it is.
Why all the fuss? I just use a big eyebrow tweezer to grip it and it works fine. The eyebrow tweezer also works great for replacing Chinese Incabloc springs that fall out. -
By nickelsilver · Posted
Naphtha covers a number of different hydrocarbons, including what is commonly called lighter fluid, aka benzine, and then some seemingly more nasty ones. Some talk with CAS numbers in this thread: I'm quite sure the naphtha I got in that post was the bad stuff, definitely not something you want to be around much. -
Guys, do You believe that the 'nut' pops up above the rotor surface enough to be cought by a wrench? -
Inflation is still alive and well, so I don't think that we will see prices coming down anytime soon. Seems that many people picked up this hobby because of the pandemic. That was my case. Of course, us newbs needed cheap watches to work on, and tools and supplies. So, I'm sure that helped drive up the prices as well.
