Pivot Sizes
Scouseget
I've been having lots of fun, and a good deal of frustration, working with a couple of English fusee pocket watches from around 1875. Surprisingly, I've been able to semi-master the intricacies of the fusee cone (dismantled, cleaned, lubricated, and reassembled) and chain (which was broken but I was able to repair it with the tiniest of rivets
), but am being presently stymied by a broken English lever arbor pivot on one of them. One end is not only broken but also missing so I can't establish the diameter, so my question is, are the pivots usually the same diameter on both ends of any arbor? This can be for a balance, lever, or indeed any other wheel arbor? Can we make that assumption, and if not, how do you make a replacement arbor, which is next on my work list for this watch, if you don't know what diameter to make it?
I do realize that I can simply try the remaining arbor in both jewel holes and try to establish the size that way, but it's a bit inexact and frankly I don't know how much clearance is normal, i.e., if a jewel hole is, say, 0.15mm, what size should the corresponding pivot size actually be?
I see that occasionally jewel gauges come on sale on E Bay, but these appear to be rare beasts at the best of times, and are usually prohibitively expensive so is there another method of measuring a jewel hole size?
Finally, why wouldn't the pivots be the same size on an arbor? Presumably the loading on each of the pivots would be the same so logic dictates that the sizes could also be the same, or am I missing something and making too many assumptions?
As always, thanks in advance for any light you can shed on this.
The first photo shows the broken arbor. The second is the fusee opened up. Amazing precision given the technology of the day I think.
For starters, you need the right tools to begin with. A good lathe and milling. The arbor is made out of a single piece of steel. You need to measure both holes in the plates and barrel, then you need to be able to draw up plans and design the arbor, taking a look at others will help.
Do you have a lathe?
You can then turn a series of trial pivots of a known size, pressed into a small brass handle.
1 hour ago, oldhippy said:
I wouldn’t think this type is expensive.
Depends on your idea of expensive.
Second hand anything from £50 to £120.
Its on my want list, but so are many other items
I think he was referring to my post which was about the pivot gauge for pivots, not your post about the hole.
On clocks you can measure the pivot hole with a smoothing broach and then a vernier or micrometer on the broach, I've never tried to measure the pivot hole on a watch, but can you do the same if you have fine enough smoothing broaches?
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
    • Ohh spooky I have just aquired the same one mike, but mine has a drill bit inside it.
