I have posted this other long vid. because it contains some very interesting info on what is happening within the watch industry. Breitling's sale it's amalgamation with "Tudor" and also the guy states that ETA are now looking for companies to buy their movements and will now will supply parts until 2020.
All very interesting CB.  It's great to here Swatch not getting it their own way for a change!
As an aside, the background that the guy was standing in front of was really weird the way it moved, it was surly computer generated?
All ETA are doing is extending the period of uncertainty within the industry now supplying parts until 2020 is fairly meaning less its not going to instil confidence in small manufactures to buy ETA movements knowing that in a short while parts will dry up other manufactures are not sitting on their hands. ETA are only playing games with the market supply movements and fend off competition from other manufacture and as soon as things are in their favour stop supplying movements again.
This is a re run of the late 70's and about time, Omegas, and Breitlings prices are just ridicules at the moment. £2,215 for a quartz Breitling Colt on rubber strap, it seems every other week Omega launch a new limited edition Speedmaster while trying to flog a dead horse, Not being quick on the smart watch uptake and relying on the far east market has really burnt these manufactures prices seem to have been driven upwards for the last 10 years by their insatiable consumption of luxury goods now thats drying up prices should be going down not up.
I hope the crisis deepens and they receive a real wake up call its long over due.
5 hours ago, vinn3 said:
sad to hear,  vinn
Why sad. As Geo noted, The news is that the biggest Swiss manif. is coming back to its senses.
It is. And the  entertainment spin the guy used on his rant got me bored after 40 seconds :)
Edited by jdm
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
