TagDocPa55
Haha..why pay someone else to screw it up when you can do it better yourself!
Pulled apart a Ford Cortina gearbox and put it together again because the shop wanted $$$ for a second-hand box without guarantee. New bearings and some synchros and it worked fine. (I knew I could do it because I had all of two years experience taking apart my 100cc motorcycle!).
Flush with confidence I then tackled the rear differential which was whining. Swapped out the bearings and took it on a test drive.. went ok until 20miles later it locked up and caused a massive jam as it couldn't be pushed off the road. Bought a second hand one but found that I performance had dissapeared (this was a mark3 GXL with a 2L). Turned out the replacement diff was from a wagon or something else (1.6?). To cut a long story short, I learned a lot about gear-meshing and final drive ratios but those lessons once learnt stayed with me forever. I also learned that sometimes the money spent to send the car to a guy with a lift was well worth it compared to spending a few hours on your back under the car juggling a jack and gearbox trying to get everything back together.
My biggest f-up tho was bolting a big end onto a crankshaft bearing .....
Anilv
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
