Beat Error and Positional Error
I'm glad it worked out well for you. Must feel good to learn some new watchmaking black magic huh? 😂 Can you post a photo of the crown after all this, I'm a bit interested in how it looks compare to how yellow it was before, never thought alum could dissolve oxidation as well, maybe I can work out the chemistry behind it, something to do with the electrochemistry list, but I'm too lazy for it so 😂 you are lucky it was only yellow, the layer must be so thin it didn/t damage the finishing enough to be noticeable.
By ClaudioCavalli · Posted
Thank you Andy, I will keep that in mind. Fortunately this time, I tried to drill the stem out before finding out about the alum method, therefore most of the stem was hollowed out. When I took the crown out of the third bath, I was able to screw the whole replacement stem in. It us now in the ultrasonic cleaner to get any remaining gunk out. claudio -
I haven't been on the forum for a while 🙃 A family member had a 955.112 watch running with an intermittent fault. Bought a NOS 955.112 movement, but to be sure, I'll give it a full service. It has been a long time since I did the 955.112, so I went back to @VWatchie walk-through ........ Again, I'm struck by the quality of it ❣️ Superb work 👏 🫶 🙏
Hi Neven , Agree we you that guard pin is in general a suspect , but OP replaced the fork, no joy. Perhaps roller is damaged or misses the guard pin, so OP is going to check the escapement with high magnification & adjust end shakes as well. Regs
If you're running at 70° C you can use a lot stronger solution than you've got. I use around the same strength solution as you and at at 40° C it takes about 5 days to completely dissolve a 0.9mm Dia. stem
