Checking my Marvin Hermetic
WillFly
I like to pick out a watch from my collection from time to time and give it a check and run to make sure it's working OK. I was wearing a particularly tight (round the wrist) shirt and sweater the other day, which make checking my watch difficult, so remembered I had a nice 1950s Marvin Hermetic on a Bonklip strap. The Bonklip was designed to be worn outside a shirt or jacket in cold conditions where it had to be referenced easily without constantly pushing up clothing - hence its popularity in aviation.
Anyway, I checked out the movement - the regulator is bang in the middle - and have been wearing it for several days now. Perfect time running; a little stiffness when changing the time indicates a clean and lube is probably in order at some stage.
  • Like 6
A good looking watch !
I like the easy to read face.
I once had an Omega Speedmaster but could never see the small dials without putting on reading glasses. Eventually sold it and vowed never to have any timepiece which could not be easily read with 71 year old eyes !!!!!
I know what you mean (I'm 73 this year). I've seen some incredibly expensive, amazingly designed watches with innumerable complications - that did everything but display the actual time efficiently!
That's why, for example, I would never buy some skeleton watches - the background of the movement distracts from the time display.
The Marvin is on the small side, compared with today's gas meter dials - around 32mm - but I don't mind dial size as long as the watch is comfortable and elegant.
Marvin watches are very underated and as a result they are good value, an inhouse movement if I'm not mistaken.
Only thing is most of them come in Gold-plated cases which wear terribly. Willfly, yours is one of the few stainless steel and its in beautiful condition!
Anilv
All Marvin movements, as far as I know, were in-house, as you say. The one in my original post is a 520 movement. I also have a 510 which is good, bit not quite as smart as the 520, as  you can see below.
I love the Marvin's and the wind like no other watch that I have owned. One that is close is an old 20's Imperial winds almost as smoothly.
fantastic piece I have one that I love wearing and needs servicing.
    • While you might have seen it as a humorous/Dramatic remark was done very deliberately so I could get an answer. Let me quote myself? The simplistic of this entire discussion is the group would like the last forever.   If you go to the top of the discussion group you'll find something to click on that says staff. Then you click on Mark's name and you find out interesting things? For instance he was last here on Saturday so yes he is here. If there is a crisis or a problem he is going to be here. You will also find a list of his activity although that's only the public activity. There's a lot of work that goes into running message boards and he probably does a lot of stuff in the background that we don't see to keep it going. Unfortunately message boards do not run themselves. Then regarding this did you notice you can message Mark and ask him. Then if somebody, we could elect somebody from this discussion such as @Neverenoughwatches To reach out I would really keep the message super simple like? You could refer him to this discussion but I would really keep it simple Like for instance the group enjoys his message board and what could we do to keep it going Forever? Then regarding all of the other suggestions comments helpful remarks or ideas? When was the last time any of you bothered to read the message board rules? This is covered which is one of the reasons I did the dramatic things I did to provoke a response of the basics as opposed to starting to suggest or seemingly suggesting all sorts of ideas which are covered by one of the rules found in the section on rules. In other words I'm going to quote something from the rules of the message board.
    • For me any input from Mark would be great. If he's keeping a close eye i would imagine he has read about our concerns here. But specifically i would like to know if he is ok with us collecting each others contact information for those of us that wish to provide them.
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
