2824-2 hour wheel
Has anyone any ideas where I can get a ETA2824-2 hour wheel in a height 4 from, it measures around 1.75mm.
Needing it ASAP and don't really want to wait from one getting delivered from abroad.
Gleaves and Cousins are out of stock
Edited by Tiktok
Check with John Senior (http://www.obsoletewatchandclockparts.com/255-hour-wheel.htm) just because he doesn't list it doesn't mean he doesn't have it.
I would also check May Moorhead at Northern Watch and Clock Supplies.
The "where used" list below for this part is pretty extensive.  You may like to check some of the other movements at Cousins
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=Va_D^HW
Thanks for responses, tried Jonh Senior but no luck,
ordered a height 5 from cousins and will just have to remove .25mm off the pipe, not ideal but a solution.
The problem I am having is the one from a 2836 is listed as interchangeable but it has a step in it because in a 2836 it has the plate that keeps in place, the 2824 just has a dial washer with no step. Everywhere I have found it in stock for 2824 when questioned it's actually for a 2836 with the step in it and I don't really want to use a dial washer with the one with a step in.
We will see tomorrow when the height 5 from cousins turns up if it's the correct one.
You can try Otto Frei
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
