as 1900 setting wheel
Yorkie
hi
newbie question, stripped down my first movement, an as 1900, using mark's video.
the setting wheel came off ok, but for some reason it wont go back on, as i am rebuilding for practice
tempted to warm it up a little, as i have basic tools and no broaches etc yet.
any thoughts?
many thx
12 minutes ago, Yorkie said:
hi
any thoughts?
many thx
Aahh! You've been stung by lady art!
My 2 cents are that nothing should be forced into place except maybe for the mainspring... and that if you load it by hand, because the winders make it a lot easier if it's the right fit.
I would recommend against heating anything up to make fit as this may change the density of the metal.
You have to find what it is that you may be missing that is keeping you from placing the wheel back on.
A picture would be very helpful.
Cheers!
I'm wondering what part you are calling a setting wheel . On July 30 , 2016 I posted for help in this column for an AS 1746/47 and I used Marks AS 1900 video as a reference . The part I was working on is called a Great Wheel and on the same shaft there is another wheel attached called a Canon Pinion with Claw Notch .
Both calibers , 1900 and 1746/47 use this set up with a difference being on the 1746/47 the Great wheel is on the gear train side of the plate with the shaft going to the dial side of the plate through a jeweled hole and then the Canon pinionW/ claw notch  is pressed on the shaft . These gears are used both to turn the minute wheel in normal operation and also used for setting the hands . I think this mechanism is called an offset pinion .
hi jguitron, ok wont force it, and wont heat it, picture below.
Hi ricardopamino, thx for the help, does photo help?
guys photo,below, its the wheel at the bottom, part of keyless works?
i dont believe it perches on top of the 'spindle', (for want of a better word), i believe it should slide down the spindle?? maybe i am wrong.
thanks again.
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
