Flea Market hunting..
anilv
Spent a few hours at a flea-market in Seremban, a town in Malaysia about 50kms or so south of Kuala Lumpur. A lot of junk but that's sometimes good as you may get some bargains here. There is another bigger (better?) flea-market in Kuala Lumpur (in Amcorp Mall) but here the stuff is more 'antique' and priced accordingly.
Anyway first one up is an Orient Racer, pretty much the bottom of the barrel when it comes to condition but through the badly scratched crystal I had a hunch that the dial was OK as the dial paint didn't have any visible patches.
Back home I got it opened up I was happy to see that the dial was in pretty good shape with just some dust on the surface.
The missing minute hand was also in there but the seconds hand was AWOL.
P_20170108_163436.jpgack
The caseback is not correct, its too small and won't screw in..damn.
On the inside I'm pleased to find an Orient 1942 movement.. nice as this has a full balance bridge as opposed to a balance cock. However the autowind stuff is all gone, since this watch cannot be hand-wound this watch will end up being a donor unless I can find another one with a good case and autowind  mechanism. This was a better movement in its day, the escape wheel is capped on the main-bridge. The similarities with Seiko movements can be seen by the balance shock protection and it also has the typical seiko click which is just a piece of stamped steel which functions as the click and spring. The escape wheel cap jewel is also restrained by a typical Seiko spring.
The second watch is an Urika. I was inspired by Mick's (Cad101) post and have been on the lookout for one and this was sitting in the same box as the Orient above.
Pretty pristine..
In fact not much wear.. original, facetted around the edge, crystal has normal drawer rash,, nothing that can't be polished out,,...
Caseback pretty unworn and the bracelet has the full lenght.
The remnants of the price tag on the bracelet clasp leads me to think that this was probably unsold stock.
Didn't get a picture of the movement but it has the same upside down balance as Mick's watch. Hopefully a clean and service will get this running... will post a write-up when I get round to it.
Both of these cost me MYR40... less than USD10. .. simple pleasures..!
Anilv
I'm pleased you managed to find one @anilv and I inspired you to find something out of the ordinary I still have both mine and wear them often. That crystal is great although i wouldn't like to try and find a replacement if it had been cracked.
yeah.. anything other than a round crystal is a pain to source!
  • Similar Content
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
    • The problem with oil in particular 9010 is it likes to spread. This is why you're supposed to use epilam anywhere it's used to keep the oil in place. Then you want to splurge on money you could buy 941 it's actually an oil that existed before 9415. Then the problem with the grease yes it stays in place but if you have too much you lose amplitude. Then if you get really obsessed with this he would follow Omega's recommendation for escapement lubrication. One of the problems with internal documents of the watch companies is typically are never going to see Them.But a few of them out in the wild for instance at this link Below I searched for the keyword of working. In particular working instructions of the Omega watch company for which there is way more than This but this is all they have. So you want to download number 40 as were going to talk about that and also download Number 81. Plus anything else that looks interesting https://www.cousinsuk.com/document/search?SearchString=Working Then number 40 covers lubrication of the watch. Most interesting is lubrication of the lever escapement under three different conditions with Lubrifar Which you probably no longer have has been washed off without which is what you have and then a course with epilam. Notice how they go supers super minimalistic with the 9415 because if it's too heavy you lose amplitude. Then if you lose amplitude the group will be disappointed with you and the end of the world will come.
    • You would always get an answer John, you dont need to be dramatic or humerous to get one, but it was appreciated anyway 🙂 Kind of, for those of us that wish to stay in touch and continue to learn from each other in case the forum ever dissappears then yes i suppose so . I  hope that you would also count yourself in , what we learn from you is invaluable,  how you benefit from that exactly I'm not sure, being able to teach ? I did say is it ok to ask mark for some input John and suggested that he might read the thread that explains how some of us feel. I dont see how its really discussing forum policy, but in all honesty i wish i had never even bothered now.
    • While you might have seen it as a humorous/Dramatic remark was done very deliberately so I could get an answer. Let me quote myself? The simplistic of this entire discussion is the group would like the last forever.   If you go to the top of the discussion group you'll find something to click on that says staff. Then you click on Mark's name and you find out interesting things? For instance he was last here on Saturday so yes he is here. If there is a crisis or a problem he is going to be here. You will also find a list of his activity although that's only the public activity. There's a lot of work that goes into running message boards and he probably does a lot of stuff in the background that we don't see to keep it going. Unfortunately message boards do not run themselves. Then regarding this did you notice you can message Mark and ask him. Then if somebody, we could elect somebody from this discussion such as @Neverenoughwatches To reach out I would really keep the message super simple like? You could refer him to this discussion but I would really keep it simple Like for instance the group enjoys his message board and what could we do to keep it going Forever? Then regarding all of the other suggestions comments helpful remarks or ideas? When was the last time any of you bothered to read the message board rules? This is covered which is one of the reasons I did the dramatic things I did to provoke a response of the basics as opposed to starting to suggest or seemingly suggesting all sorts of ideas which are covered by one of the rules found in the section on rules. In other words I'm going to quote something from the rules of the message board.
