Which watch lume to buy?
Tmuir
I'm about to place an order with Cousins to buy some tools and oils / greases and was thinking about buying a Bergeon green lume kit as I've got a few watches that are cheap enough for me to practice reluming on, but whilst doing some reading up on reluming hands today I came across a number of references Super Luminova with a few of them listing it as superior to the Bergeon Lume.
What does everyone here think?
Should I just buy the Bergeon Lume kit, or should I source from else where the Super Luminova lume kit?
Thanks
Tony
Thanks everyone. I got the response I was kind of expecting, everyone has their own preference and there is no one clear better lume.
I'll get the Bergeon lume since that is what Cousins sell and I will be placing an order with them tonight anyhow.
i bought some lume from an ebay seller a while back. i am reasonably pleased with the lume quality, but the binder has an objectionable smell. chemical smells usually won't bother me, but this does. i hate working with it. what i've been thinking about using is UV activated nail polish. it won't harden until exposed to UV light - which is sunshine.
Tried all. Nitrocellulose nail polish, UV nail polish and akrylic lacquer. All are good but the nitrocellulose nail polish is convenient to use.
Never bought a branded (expensive) lume paint but it would be nice to see a side-by-side comparison of sample spots made with the same binders and solvents in the same amounts. I have brought my relumed watch to a local watchmaker to compare its lume with a good lumed watch. It was a TAG Heuer F1. The initial brightness was about the same, but the most interesting would how the brightness changes with time.
Could You or someone else make this comparison? I dont want to buy that expensive set just for this :)
Humbrol Matt or Satin model paint is what i use? Tried some acrylic paint but i think i dry out to fast?
I emailed Humbrol a while back asking for a Matt lacquer that dried slowly.
They replied with this..
Humbrol AC5601 Modelcote 28ml Matt Cote.
Humbrol AC7501 Enamel Thinners 28ml.
My local model shops don't stock it so I never got round to try it.
Sent from my Honor 5c
I personally do not like the luminous powder from Bergeon that Cousins sell - It looks way to green in daylight - "mint green" instead of the white colour most powders have!
I use lume on routed watch dials and like it when the particles are 2-3µm instead of the standard 10µm - or the surface gets scratched in the process when making dials. The smaller particle size also makes reluming  hands much easier, so if you can - get a powder with a small particle size!
That is not true. The bigger the particles the brighter the lume at night. Moreover, particle size has a great impact. Yes it is harder to work with bigger particles, but if one gets to the appropriate mixture of binder, solvent and powder, then the result will be much much better. I have used the 30-70 µm batch. Ordered some sieves from the ebay to get four sizes batches.
Quote
....and I never stated that smaller size had better lume - I do not know where you got that from!
BUT smaller particle sizes are much easier to work with, you get a better finish and in my case - it is crucial for getting the work done at all.
Neither have i? Use this small cans? Not sure why they are packed in Sweden? Or why we in Sweden have special cans? Or if the paint are the same as in England or the rest of the world? DSC07647.JPGDSC07645.JPG
Edited by rogart63
  • 6 years later...
I don't have a great deal of experience in luming hands, and am watching this thread closely to see which lume you guys recommend. Can anyone let me know where I could buy Super Luminova and the approx price, compared to the Bergeon?
On the subject of binder, I watched a YouTube video of the Nekkidwatchmaker (of course I can't find it now to supply a link) and he used a method where he used 50:50 mix of IPA glue (the white glue your kids use at school) and water as the binder. I tried it a few times with good results, the IPA dries clear so the final lume powder colour is unaffected. As IPA glue is "cheap as chips" its worth a try with some spare hands etc. to gauge the results for yourself, I would be keen to hear if anyone else has good results also.
    • Hi @Michael20 I am no furniture man my self but it’s just bits and pieces I have picked up over the years. It just takes patience when dealing with things like the cases but most are veneered plain wood. When they get damp and open up that is a problem
    • I often get an amp drop after i oil the stones with 9415, not sure what difference can be achieved with oiling the teeth.  I guess the oiling surface is very small on a tooth as opposed to on the stones a larger drop might have more drag as the teeth plow through it. I oil with a bristle from a brush now, strangely enough the last movement i oiled five escape teeth and the amp was much higher than i usually get , coincidence ?
    • Who'd have thought to look at the supposed compatible calibres ?  🤔 Frank did 😅
    • I recently helped my mentor to service 7 Seikos and he told me not to lubricate the pallets. His reason was from his experience from the advanced classes that he conducted, his students all ended up with worse amplitudes after oiling the pallets. I have to admit that I had the same problem when I oiled the exit jewel, like so many videos on YouTube show. I actually ended up with worse amplitude.  But now I oil the escapement by oiling the teeth of the escape wheel. I think Rolex used to train their technicians this way. I find that I get about 20° -40° increase in amplitude oiling the escapement this way. I've only started playing with epilame recently. I got a bottle from a Chinese seller on AliExpress. It's supposed to be Episurf Neo but everything on the bottle is in Chinese. When the bottle arrived, half of it had evaporated or leaked. And when I brushed on a thin layer on a mirror, it dries rather slowly and even feels a bit tacky. When I did the oil spread test, like my experience with stearic acid, the treated and untreated surface of the mirror yielded similar results. The contact angle of the oil drop looked about the same for both the treated and untreated surface. When I epilamed an actual pallet fork, the escapement was so sluggish that I couldn't even get 180° amplitude. I dunno if I got conned by the seller but the results are just not convincing.
    • I usually just use 2 pair of pliers to remove the roller ( just kidding  🤔 )  I want one,I have an adjustable free standing one. But i really like the little bradux tool that nips under the roller with two tapered jaws that lift it off. You can get under a scope with it to see in detail how the job is going. There is some technique involved to stop you chopping the staff, doesn't particularly matter if the staff is already broken but it naffs up the tool's jaws if you crunch the staff, and the jaws need to be in good shape to prevent damaging the roller. But well worth a try if you've never used one and you can find one that hasn't been misused or buy a one new. The trick is to keep one of your fingers between the two arms to soften the squeeze, with a little practice its a handy little to. I will now prepare myself for an onslaught of negative feedback on it 🤣
