ebay purchase movement, which is OK, except the second hand post was missing. Probably why sold as spares or repair. Also have found one of the dial screws is missing
Fortunately tracked the movement down on www.ranftt.de and then on www.oldswisswatches.com, and tracked the movement down as an AS1674 and luckily found the part on ebay (the part cost more than the movement!!)
Case will be 3 pieces: case back with movement holder, case body with lugs, and bezel. Raw materials;
Case back with movement holder in brass. 2 pieces of 3mm brass sheet to get the thickness
Case body will be steel tube, with brass lugs silver soldered on. Plan  to blue the case body to see how it looks against the brass. Bezel will be polished mild steel
The picture just shows the second hand post in in place and movement seems to be working fine (not cleaned)
Left to do is bezel, dial, dial markings, hands, glass and crown - fingers crossed!!
  • Like 5
You have the patience of a saint and the hands of a master craftsman.
I'm not easily impressed, but this is so far over the top, that bluing just "pops" off the brass, solid movement as well.
You should (and will) be proud of your work and skills, Top Drawer!
Dave
Hi Watchtime, yes it is heating polished steel. It is not permanent so not really suitable for a watch case, but this is playing. Towards the end of the project I will spray with laquer to see how that improves the durability, and also it will help seal the brass
  • 4 weeks later...
A bit more progress. Should be able to get a few more hours this weekend to get the hands finished
4.jpg.12ad89ef476997504136db5c63157214.jpg5.jpg.7bdebe9057f9ea8c62406da79ab6659a.jpg6.5.jpg.259e4a2ed5b9c1a751f1bdfdf5478ceb.jpg6.jpg.d38a6caa7f8e98edf9a3c0b11235d2eb.jpg8.jpg.ca48e3b39c88336225d595bfe92daaa8.jpg10.jpg.58c417152d7df692a938f07ddf64ecad.jpg11.thumb.jpg.09ef39b1cf586bc7a7e10235b0d9386b.jpg12.jpg.6d5ded08369709c9ffc752cfcd39ef04.jpg13.jpg.7c9f9b0dc6742e4c2f3e721cffa816a5.jpg14.jpg.0da13de9b54ad798e58067c6dd7e1a14.jpg15.jpg.7b53a6b3db5bdaece39ce74ad58b8a0f.jpg8886.jpg.c2f55ddaf5bf630a6e6ffaf5cb32b473.jpg8887.jpg.4da33b160b49c031443e298070648c25.jpg8888.jpg.0c64fe9bcc7e5f53b4d12d771c1dafc8.jpg9911.jpg.ec8e24a83608cd282278202c0408dfaa.jpg111111.thumb.jpg.627f242cd525da2be01460c4fda64ddc.jpg
Edited by Michael
pictures all loaded twice
Hands completed and date viewer / hour markers made. Also did a layout to start seeing things coming together589762b63b1f5_No210.jpg.30edba5bc8b5baa0f733e2361252362d.jpg589762bb8b76c_No211.jpg.7167a5b314e54bb951713927c797863c.jpg589762be09608_No214.jpg.c848a6da19ac65d1340500c367f92339.jpg589762b7f2471_no215.jpg.45f5aabd09214d4bae58d0c8227b81e4.jpg589762b9ec68a_No216.jpg.21a32d01bcb6644b008b5986052fb8df.jpg589762b2c9325_No218.jpg.6cb7bd7104a05453069f64066bc87915.jpgsmall2.jpg.3aa4a82691aadf60bb9d85a70527273f.jpg
  • Like 5
This project has got to the stage where I am getting glad it is over. Anyway, crown made, parts sprayed with clear laquer, acrylic fitted and strap fitted. A few other problems I had to deal with to get the watch keeping regular time. The watch now keeps good time and I will regularly wear it and see what snags come up (which I am sure they will !!)
58b206963b926_IMG_4020small.jpg.f744403d830fd2035b0988bb7a4aaba7.jpg58b2069b9905a_IMG_4018small.jpg.d0fad549491cfe23090a85c74ddc2ef1.jpgIMG_4031small.jpg.d0dd210d8424722acd8e23d8536750ac.jpg58b206a1bf156_IMG_4016small.jpg.0f37936852587460cba28e7468c1d1de.jpg
  • Like 7
Well done, you have achieved an impressive objective and demonstrated some excellent skills, it has been a pleasure to track this post.
Cheers,
Vic
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
