Work benches / Desks
Tmuir
I hope in the new year to get myself a permanent work bench / desk.
Where I live getting an actual watchmakers work bench is just not an option so I'm left with making or re-purposing something else.
I'm not a carpenter so making a workbench from scratch is not going to happen, so I'm left with trying to make something else do.
One option is to put together a workbench using Ikea furniture as others have done with the difference I would buy a solid wood bench top and put roll guards on the side and back and route a lip on the front, or buy one of those height adjustable desks like this one.
http://www.officeworks.com.au/shop/officeworks/p/stilford-electric-height-adjustable-desk-1600mm-jbstiha16
Has anyone else tried to use a desk like this in particular how stable are they having only two legs rather than four like a normal desk?
Hi, an adjustable frame from Ikea is not expensive.
http://www.ikea.com/nl/nl/catalog/products/S49084965/?cid=a1:ps|a2:nl|a3:shopping|a4:S49084965|a6:google|a7:ikeanl|id:S49084965|cc:915&gclid=CjwKEAiAs_PCBRD5nIun9cyu01kSJAA-WD-rPsS_Rj1-Uq9KZXWs2BF8CSgHW9eyCO6gow8VFNl4ARoCU37w_wcB
Here is also a link for the Bergeon workingstation, it has a drawing with the sizes. Maybe it can be of help.
http://www.watchtool.co.uk/bergeon-7870-dune-watchmakers-workstation-p-7723.html
Or this, built by watch enthusiast Arie Kabaalstra in the Lowlands. He uses a alu profile cut on the right size.
Edited by Watchtime
Thanks I didn't know that Ikea did a cheaper version of the adjustable desk, that is now on the top of my list.
For the price of the Bergeon desk I would expect the watches to fix themselves once I placed them on the desk. :D
Yeah, the Bergeon has a built-in watchmaker.....LOL.
This dutch guy made a project of it and posted photos every other few days. It seems pretty straight forward to make the frame with this aluminium profiles.
 Then again, with the Ikeatable, you are for 80% done in 1 go. For drawers, they have these for only 60 euro
http://www.ikea.com/nl/nl/catalog/products/10192824/#/70342284 put on a set of wheels and you're done.
I do like the project desk, but I am mindful of my spare time.
I would rather spend my spare time learning and improving my skills repairing watches and clocks than building a really good desk to work at. I am hoping towards the end of next year my skill level will of improved enough that I can make myself some 'pocket money' repairing clocks and servicing basic watches.
I did look at those IKEA drawers and was wondering on them or to try and find some drawers that are not as deep but have more of them, but drawers can come later the work desk is more important.
Hi Tmuir,
This is what I did, the table with white legs is from ikea my friend made me a simple raised platform as I found it was to low and starting to make my back ache.
this is what it use to be like.
if you need more info give me a shout......
Regards
Kaz
I've posted elsewhere about my own adjustable desk/table, which I am very happy with. I think mine probably cost more than the one you listed, but it has a greater range, lifting capacity and a (heavy) wooden desktop. I didn't consider the IKEA hand crank type as I have my microscope clamped on the surface, and I think you are supposed to clear the surface when changing height.
The top is completely stable, apart from when at the top extreme height which I do not use.
Stephen
Yes I would prefer an electric lifter rather than a hand crank, I'll see how my bank balance is looking towards the end of January as that will make the derision as to whether I get the cheap Ikea one, or a better quality one.
I'm in the process of a remodelling of my workspace, bench and storage, so will post some photos when my drawings, measurements, and ideas are realised, I have the lumber already, and two full size office desks which will be the structure to which I will be building the wooden framework on to raise the working height of my main work area.
  • 5 weeks later...
On 30/01/2017 at 6:26 AM, SSTEEL said:
And its almost done, the ALVIN covering needs to relax a little while longer, then I can adhere it down with double sided tissue tape, and then add mat edging, and finally unpack my tools, and resume work.
32450683322_b674c0cbd1_k.jpgAlmost there, covering needs to relax a while longer, then to adhere and trim by Micky Aldridge, on Flickr
Stunning old lad I wish I had that much room.
Aint that the truth.
Total I fit some edging to my working areas :)
32576408381_f45fe0682b_z.jpgDSC04920 by Micky Aldridge, on Flickr
32657971846_469a21de66_z.jpgDSC04921 by Micky Aldridge, on Flickr
32576409331_0965d2e7d1_z.jpgDSC04922 by Micky Aldridge, on Flickr
Currently only secured with hot glue as I wanted to see how it looks, and then remove it again to stain it to match my vintage drawers.
Edited by SSTEEL
 Can't get the picture of you standing in your vintage drawers working on watches out of my head..................it ain't pretty! :startle:
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
