propper way to remove a balance
thessler
Hi
I am still new to this so please excuse my basic questions.
I have seen two different ways to remove a balance, I have tried both and one got me in trouble and I fear the second way.
First way I have seen and done is to remove the cock let the balance hang and just pull it out. . In my experience the balance got temporarily hung up and shot out creating havoc with the balance spring, wich gave me plenty of practice untangling balance springs.
The second way I have seen it to grab the balance and the cock as one unit in the tweezers and remove.
My fear of this and it may be unfounded is it would seem like a very easy way to bend the top pivot squeezing the balance and cock together on one side.
Please advise the generally accepted practice.
Thank you, Tom
I  agree with your concern and have asked myself the same question. However, I have done either way without any damage. I think that professionals prefer the first method, and they also use a balance "tack" to hold the cock, which I don't think will ever do.
20 hours ago, rodabod said:
For a typical Swiss lever, twist the cock (I usually go anti-clockwise) as you lift to help the impulse jewel on the balance disengage from the pallet fork.
That's fine but the OP specific question was:
Quote
Your take?
Where did you see this? Sounds like a great way to break a pivot to me. Angle the staff while the pivot is in the jewel and ping!
Let the balance hang, but it takes practice to get the twist and turns right so that it comes safely out of the movement. As you get better at seeing what's interfering with what, it will get easier. Every caliber is a little different, sometimes pivots hang up in the jewel, etc. etc. but you'll get there.
On one of the first movements I did I took the balance out and put it back at least a dozen times in order to gain a bit of proficiency.
Have fun!
If the upper jewel is removed first (as in good practice when servicing), the pivot is not compromised.
Your take?
My take would be what forum member Dadistic said. I don't like the idea of lifting out the balance and cock as a whole, though I guess it may be safe to do if the cock literally never slips within the tweezers.
Rather embarrassingly, I actually had an Omega cal 552 balance spring get tangled the other day when removing as it suddenly leaped out during removal. Couldn't get that tangle to untangle which is a real shame, but I have a spare balance complete anyway.
I seldom use the 'dangling balance' method. It's always been holding the balance and cock together in the tweezers for me.
The only times I've dangled the balance is when I remove the balance without removing the movement from the case..(pure laziness).
Anilv
This is the method I employ but I should note there are a few precautions that can be taken to keep the balance from getting hung up.  If you've watched some of the YouTube videos posted by @Mark you'll notice his careful manipulation of the balance wheel and balance cock prior to lifting both away from the movement; it's these little maneuvers that are key to pulling the balance away without it catching on anything.
Some things to consider:
  1. The center wheel is usually the biggest obstacle so keep an keen eye on it
  2. Dried oils will can cause the balance to stick to the movement- removing the jewels first (if possible) will help
  3. A quarter turn on the cock left or right when lifting will help disengage the roller jewel from the pallet
  4. Go slow and steady
By the way- you can separate the balance from the cock before removing either from the movement if the balance is fitted with a Breguet hairspring.  Whether this is considered proper or not I do not know.
    • if you're trying to keep track of conversations scattered all over the message board emails are an absolute must.   looking at the bell icon on the top of the page versus the emails today it looks like I got the correct amount of emails. So making some minor change based on the one of the images up above I started getting notifications again. But at times I still have a suspicion that something isn't quite right. I have some feeling that the message board may delay sending emails until something so seems to be a long delay between when you get your emails just a weird feeling things aren't quite right oh  and then even though I do seem to be getting emails I no longer get notifications of personal messages I don't find that out until I arrived at the message board where I'm pretty sure I used to get notifications of those two. So something is definitely changed on the message board. then for everyone not getting emails you do want to check your spam folder. I have found that sometimes were open up an email the system I use warns me that it thinks the email is evil and bad and I have no idea why he thinks some of the emails are and some are not. But this is actually the program I use not the email system which also has a mind of its own as to what it considers spam so you should always check your spam folder.
    • 10.46 according to Google. What do I do with it once I have the measurement in lignes?
    • If you Google "site:watchrepairtalk.com Unruh" it should answer your question. https://www.google.com/search?q=site%3Awatchrepairtalk.com+Unruh&sca_esv=cd1cd8ba04cfc6b9&rlz=1C1BYYL_svSE993SE993&sxsrf=ACQVn08-tJuTdvkJ1CZdy5PcUR7BB6zDaQ%3A1714681373604&ei=HfYzZtTBJPf8wPAPnsySiA0&ved=0ahUKEwiUxLTx5e-FAxV3PhAIHR6mBNEQ4dUDCBA&uact=5&oq=site%3Awatchrepairtalk.com+Unruh&gs_lp=Egxnd3Mtd2l6LXNlcnAiHnNpdGU6d2F0Y2hyZXBhaXJ0YWxrLmNvbSBVbnJ1aEjfCVAAWABwAXgAkAEAmAEjoAEjqgEBMbgBA8gBAJgCAKACAJgDAIgGAZIHAKAHLQ&sclient=gws-wiz-serp
    • If you loosen the case back does that make any difference?
