Can I use D5 in place of 9501
Tmuir
I received another box of goodies from Cousins this week which included my oils and grease.
I already had 8200 for the main spring, but purchased D5, 9010 and 9415, but my budget could not stretch to include 9501 at the moment. For now I will only be working on simple manual wind movements, so bearing this in mind can I use D5 on the keyless work instead of 9501 until my budget can stretch to get myself some 9501?
thanks
Thanks. I will get 9501  probably in the new year when I place my next order from Cousins I just dont want to wait until them before I can start practising servicing watches.
I can always strip them down again at a later date and clean and re-oil them again I just want to get started now
3 hours ago, matabog said:
I heard 9504 is better then 9501 (for the cannon pinion)
For the keyless work I believe hp1300 is better then d5 (better marketed, anyway)
Not just marketing, 9104 (HP1300) is a synthetic oil and that makes a difference in lasting. D5 is still on many service sheets simply because these predates the introduction of more modern formulations, and will never be updated.
9501 and 9504 are very similar greases and Moebius state that 9504 has 9501 as its base.
9504 differs from 9501 in that 9504 has a heavier base oil (synthetic), has a more stable soap structure (soap is the thickener which holds the oil) and has added EP (extreme pressure) and anti-wear additives.  On this basis it would perform better in high load areas, but in most cases the cheaper 9501 would suffice.
I would always go for synthetic oils and greases if you can afford them as they are more stable, will retain properties much longer, and generally have higher performance.  Most standard 'synthetic' oils are basically 'synthesised' from mineral crude oil and so are fully compatible and will not be detrimental to seals etc.  Some synthetics (eg 9415) have a different structure.  Care is needed when plastic parts are involved (the oil may not be wetable enough) but generally these are not a real problem if quality watch oils are used.
Edited by canthus
typos
Thanks @canthus. I stopped short of suggesting the use of 9501, but I agree that it can be used, and is probably a better choice than D5.
J
8 hours ago, noirrac1j said:
Is this the same as Lubeta V105? Not really for the keyless works.
J
No, nothing like Lubeta, it is not a liquid it's a grease. I originally used it (as recommended at the time by ETA) for chronograph parts that come in contact with each other.
I have been using it for some time on sliding pinions, cannon pinions etc and not had one watch come back or fail.
Molykote Dx is also a good grease but getting a bit long in the teeth now.  9504 has similar base oil viscosity but Dx is mineral oil so will not give the same life/performance as 9504 with synthetic oil.  The soap base is basic  lithium unlike 9504's complex soap which again will give better stability for longer (the oil does the lube the soap just holds the oil in place).  Dx has a solid lubricant like molybdenum and 9504 has Boron which more stable than moly.  9504 also has EP and antiwear additives.
Dx does have the advantage of being white in colour whereas 9504 is light blue.  This may be important for visible movements. Dx is also lower cost!
Edited by canthus
added text
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
