I was just going through a used bookstore this afternoon after I got off work and came across this. Decided to take it home!9c0278fe5fddfb09e1c61086905cdc3f.jpg
Nice find.
Its really hard to find good technical books at second hand book stores where I live, but when I was in the UK in July I found several on a day trip to York which I was thrilled with.
I've got that book on my shelf but haven't read it yet, but suspect I will get more into it over the next few months as my night course is starting to move back into watches from clocks.
I really like this book. And calling it a 'bible' of repair is actually quite apt, as there are ...14 -- if i remember correctly -- 'commandments' of professional watch repairer ethics, which should be located somewhere at the back of the book. (my copy looks different to that)
Edited by Ishima
good show,  i re- read it often.  as far as i know,  theres only  one edition.   it is a very good training manual AND  it should be read "cover to cover"  UNLESS -- you are only interested non- vintage watches (including  pocket watches).  OR  flipping watches.  vinn
A standard book on the topic - every repairer and tinkerer and lover of horology should read it. It's certainly not hard to find a s/h copy and, if I remember correctly, I have it on my Kindle as well.
  • 4 weeks later...
Got this old version which I found in a watchmakers heritage I bought some years ago. As the pages were very fragile I scanned it to read it on my mac. Second revised version with wonderfull drawings....
On 10/21/2016 at 2:51 PM, parmenion31 said:
Hmm i was right , that book looked familiar to me , because i own allready a copy haha.
Looks like an "easy" read...:startle: if you can read Greek...I am a bit rusty...
Edited by MilTimeCan
in the index,  note there is no definition of  "caliber".    also in the main spring pages,  Movato has a patent on a winding clutch.  i would like to know if any other watches used this clutch.  vinn
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
