16 minutes ago, vinn3 said:
very interesting mvt.,    tell more.  vinn
The top one is a New Factory Tavannes 38 (Eberle 38) from a Waltham wristwatch I just bought.
I didn't spot it at the time, but the dial states 17J and the movement 15J !
1 hour ago, vinn3 said:
on the last watch,  i notice the "timing  lever ?",   is in full retard +.  that might mean it needs cleaning?  vinn
It certainly does, I just stripped it down today.
As you can see, there is no balance shock system, whereas the info in Ranfft shows what looks like Incabloc.
The balance cock jewel is removed by screws on the underside.
Is this an early version of the NFT 38 movement ?
Edited by mikepilk
6 hours ago, mikepilk said:
I don't have a problem - but just wanted to know what the angle marks are on the front of movements ? , e.g.
I had posted a quiz about that recently but I think nobody took it up :)
These are for timing regulation after assembly, using a temporary minute hand, a loupe and a reference clock.
Edited by jdm
Makes sense, Thanks jdm
The marks are just a guide to see if the watch is running properly. Basically you would install the minute hand and note where the needle was. ... check again one hour later and see if its at the same mark.
Not very accurate and that's probably why you don't see this from the late sixties onwards.
Anil
5 hours ago, vinn3 said:
here is a quiz for you,  how do you change a clutch in a 60 ton tank?  vinn
First you need one of these screwdriver looking thingys to open the case. ;)
You put in an emergency leave pass, and hope some other poor sucker gets the job!
5 minutes ago, vinn3 said:
the real question is " how do i start to work on a watch"?  my answer is know how open the case back and get the stem out.
When that question was asked? When is that we ran out of military humour?
