Refurbishing a Seiko 6119
anilv
Thought I'd share some pics of the watch I worked on over the weekend.
This Seiko was part of a lot of 3 watches off the bay...I was actually attracted to the Citizen but the other two Seikos were plus points as they had the 6119 movement which has to be my favourite Seiko movement.
This Seiko was a bit beat up with a heavily scored crystal but the dial and hands looked good. In the picture below the chapter ring is a bit out of alignment. A bit weird as the ring is keyed to the dial in these models. Watch was running but would get a service nonetheless.
Caseback looked to have escaped the attention of the butchers.
Opening the caseback revealed a nice 6119 ticking away...no water damage evident, surprising looking at the case sealing area. It is a mess and it would not be possible to get a good seal here.
Probably the watch was still running as it was serviced in 2010.
Well the servicing of the movement went well with no hitches. I then turned my attention to the case.
I was looking thru my parts stash for a 330 crystal I could use and found this..This would have been a typical replacement crystal here in Asia back in the day and has survived well. Not surprising it is the correct size and shape as its marked 6119-8273 on the packet!
Crystal install went without any drama as the gasket was still serviceable.
Sides were polished to get rid of the many little scratches.
And here it is on my wrist! Couldn't do much about the condition of the chapter ring but at least its aligned properly!
I really enjoy rescuing these watches and giving them a new lease of life. Hope you enjoyed the pics.
Anil
9 hours ago, dadistic said:
You must have a nice stash if you just happened to have that crystal. I have a big pile of tehm but never seem to have the one I need!
Thanks Dadistic.. The supply is dwindling fast though. I have another 2 more in this size but glass (the one above is plastic).
Anil
dadistic,
I'm down to the last two 330 size for Seiko .. these two are glass so I'm saving them for something special.
Usually I will only use them for watches which are 'mint'. In this case I was considering polishing the crystal but the dial was too nice to hide behind a scratched (even if polished!) crystal. I will keep looking for a better chapter-ring/inner bezel as the one fitted kinda lets the watch down!
Anil
  • Similar Content
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
