Seiko 5
I said at the price I wouldn't have one of these as they have no "Hack" and don't have a manual wind facility . I thought for the money I could get something better. Well now I have to "EAT MY WORDS"
A certain retailer was selling these with a 40% discount, so thought I would have one as people seem to hold these in high regard.
These watches are excellently constructed the movement particularly well made, accurate and well regulated and I firmly believe would be worth every penny of the full retail price.
hope there was no aftertaste!:D
here is better pic of Seiko 5  "military dial" (24 hour) very similar, gave this to my son for xmas, paid just over a hundy from amazon, at 42mm, way too big for my skinny wrist. You won't be disappointed with your purchase.DSCF0237.JPG
I love my SNK's. I have three of them, and I wear the heck out of them. They are cheap enough that I can bash the bejeezus out of them at work and not feel bad.
Test of a good design...cheap and tough!
On ‎8‎/‎8‎/‎2016 at 6:27 PM, Tunokies said:
I modified it to look like this. Great little watches. Very pleasing to do dial/hand swaps on.
Where did you get the dial and hands? I love what you did!
Cheers,
Bob
PS. And the matte finish bracelet to go with the case!!!
Cheers,
Bob
Hi Bob.  Thanks, it's a Sinn 656 style dial and hands, quite a common mod (usually white not orange)
The Dial and hands came from Harold Ng (yobokies) . He is one of forerunners from the Seiko modding scene. Good quality.
He doesn't have a website, just a photobucket site. http://s161.photobucket.com/user/yobokies/library/?sort=3&page=1 You have a look through, then email him for prices.  It means he's not as easy as some to deal with, but it's worth it.  I'm new on this forum but I guess you can P.M. people. PM me for his e-mail address if you want.
And yes. The SNK809 can come delivered with either the matching bracelet (which looks nice but is just folded links) or a nylon 2 piece strap.
Here's a few pics of a Seiko 5 SNZH59. Quite a nice watch as standard (top left) and after I modified one for someone to resemble a Blancpain Fifty Fathoms Dark Knight. It's a nice size and has TiCN coated stainless steel case. Also the standard domed hardlex crystal adds a cool vintage look. A popular base for a few modded watches.
Its a clasic ,  strong solid case ,good behavior in water(not diving) , cheap and many movement parts, automatic so no need to turn the crown winding everyday.
i agree with you will, the only thing i dont like  its that the accuracy its not like quartz watches and never can be , beside that its a must have mechanical watch everyone can afford.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
