Tips
Evening gents
Just wondered if anyone has advice on how not to lose shock springs etc, I managed to lose a shock spring last night but luckily found a substitute which was not an exact match but does the job very nicely.
Please tell me I am not the only one, dare I ask does it happen to pro's as well?
Good tweezers are the first tips. Rodico to hold it could also work? Depends on what kind of spring it is? A jeweler picker is a very good tool? Check it out on Cousinsuk or Google it. With silicone tip. Used for picking up the spring and put it in the box or back on the movement. download (20).jpg
Edited by rogart63
For me, dropping springs is usually a sign I'm getting tired. I may drop a part once but if it happens again I know the chances of something flying is high. Usually when I persist in spite of the warning signs, I end up on my knees with the small broom and dustpan.
Anil
I have found when releasing the spring it,s best to steady with a piece of pegwood so it releases gently without flying away. For the trior style springs I made a removing tool out of peg wood. A hole in the middle & three cut outs so all I have to do is twist & they release without any chance of flying. Or you can purchase these tools but I found my peg wood version works fine.
Just prepare yourself in spending many hours sweeping the floor on your knees so make sure you have a nice brush handy. :D On more serious note good tweezers are a must and try to get in the habit of demagnetizing your work before you start taking it apart this can save a lot of hassle.
Ah the old springy boingy things that are attached to watches. I usually work inside a large clear ziplock bag movement, tweezers, driver, pegwood and right hand inside zipped up and rest of me outside then if anything flies I can usually find it I think the longest I've searched for a spring is 2+ hours before giving up and consoling myself with a large vodka.:D
    • The bezel feels slightly loose over the case. There wasn't a gasket but could the crystal be expanded over the lip in the caseback and then the bezel pressed over the crystal?
    • The cleaner smells of ammonia, but it's not too bad; just keep it covered as far as practical.  I use an ultrasonic machine on a kitchen worktop. The rinse does not smell strongly, it's vaguely like paraffin. I did check the safety data sheets before buying it & it's said to be safe in normal use. My dedicated watch cleaning machine is still a work-in-progress; four position linear, based on 1L kilner jars for station spacing, to have a heated dryer in position 4. It uses standard, readily available parts as far as possible to make it easy to reproduce, plus 3D printed bits for the custom parts. (The horizontal drive motor is out at the moment while working on the stepper drive software)
    • I disassembled the hands of my Citizen Pilot Super Titanium Radio Controlled AS2031-57E a couple of times.  The second time because on the first attempt i evidently did not push the hour hand well and in practice it was not well fixed and moved receiving even small bumps. After the second attempt everything seems to be ok.  Except that i have the impression that giving a little more sustained blows on the wrist, the hour hand still has a slight movement, in the order of half a second or less. It is a normal, topical and usual thing about this movement, which, i remind you, is exclusively electronically managed, each hand independently, a clearance in the movement that it has of its nature, or it may depend on the hand is not yet well attached to the pin and should perhaps be replaced because the hole has slightly enlarged?
    • This is something a lot of beginners and amateurs struggle with Nev, being able to remove the staff without distorting the hole of a non steel balance wheel. Having the right tools to do this safely  and effectively is not easy. Even with something useful it takes a lot of practice, i spent two days not so long ago practicing cutting away the balance wheel hub of a staff using a 25mm diamond wheel.  I didnt manage to do it once without catching the underside of the wheel.
    • Then you should have something that prevents the case from moving. I just bought one of these Seiko S-210 but haven't received it yet.
