Finally got myself a starter lathe
SSTEEL
It was gifted to me by a good friend of mine, its a Emco Unimat PC Lathe, needs tidying/restoring, so may do a guide on restoration on this like I did with my Elma cleaner.
Onto the photos.
27262591960_927f18c2f2_k.jpgShould clean up nicely by Micky Aldridge, on Flickr
26930687923_decde91fd2_k.jpgToe dipper into Lathing by Micky Aldridge, on Flickr
27466832811_dce537b705_k.jpgWIP Lathe by Micky Aldridge, on Flickr
Already started looking for accessories for it :)
These lathes are fine for clock work big enough to take Longcase clock parts. I think it might be a  unimat 4. I know there are loads of attachments fir the unimat 3 which I had, you will need to check to see if they are compatible. No good for watch work.
Excellent Micky and congratulations on a new super tool! Me too, -- like Geo -- I'm looking forward to your walkthrough and experiences. In my particular case, I've never had a lathe of my own and might get one soon...once I decide which! There are sooo many options out there...and prices! :)
This would be an invaluable experience to share!
Cheers,
Bob
That is a unimat 3 PC . One which you can  attach to a computer . There are lots of parts for it on Ebay. I recommend new o-rings for the drive pulleys.
I have a ordinary Unimat 3 which i bought back in the 80' . Still working good.
There are a lot of parts available for it? Like collets chuck and tool rest .
Edited by rogart63
Like many other tools, a lathe choice is a series of trade offs. As a lathe becomes larger and more powerful, the element of "feel" is reduced. If "feel" is not required to produce your part, as in larger clock size parts, a larger, more powerful lathe can be a great advantage. For a tiny part, such as a watch pivot (.1mm or .004 inches in diameter) the elements of increased machine mass and power become superfluous. A set of watchmaker turns powered with a hand driven bow can provide enough machine mass and power to produce high precision watch pivots
In addition to size and power, a lathe must also have sufficient precision to produce a part to a specified tolerance. The industry standard Geneva and American WW pattern lathes have sufficient precision to produce small watch parts.  Precision, however,  should not be confused with smaller size as there are many large lathes that are more precise than a standard watchmaker lathe.
david
JDM,
If you are going to machine a watch case out of a stainless steel blank, you will quickly appreciate a larger, more powerful lathe. The inside of the case can be cored out with an endmill or specially sharpened large diameter drill bit and finished out with a boring bar. If the job was done on a smaller lathe it would  have to be picked away with smaller, lighter cuts.  This is where the tradeoff comes in. If you were to try to core out the blank on a Geneva size lathe, the job would push the lathe past the point for which it was designed. All of this has to do with issues such as budget, shop space and available tooling that everybody should consider when selecting equipment. At the very least the machine selected should be able to handle the range of parts and materials that you plan to produce.
david
No, I would just need to level off corrosion on the seal seat there or on the case back. Any specific brand or model recommendation?
JDM,
A number of years ago I purchased a SINCERE lathe from China. It is a Geneva style light duty lathe roughly patterned after the Bergeon, Lorch, Wolf Jahn Geneva style lathes. When I bought  the lathe, including the cross slide and collet holding tailstock, the cost was around $450.00. The motor was an additional $200.00.  I later purchased the milling attachment,  spring pulley assembly,  dividing plate assembly,  sensitive drilling kit,  tip over rest, file rest and the extra long bed. In all everything came to around $2000.00. Once I took the spindle out, cleaned it, lubricated it,  installed an O-Ring seamless belt, and adjusted it, the spindle run out was almost undetectable. It is a fine high precision watchmaker lathe that produces a beautiful turned finish. That said, it is a small light duty machine that is not suited for heavy duty use. As long as the machine is used for small watch size parts and not pushed hard, it should provide many years of service. The swing is the same as other watch lathes and should be able to take a light clean up cut on a watch case.
Aside from being a good quality machine, what makes the Sincere lathe a good choice over other watchmaker lathes is its affordability, and the fact that the accessories are also affordable and available.  As long as the machine is used to take light cuts with small cutters and drills it should function beautifully.
david
Welcome to the forum David, and thank you for starting off by posting quality information regarding lathes.  There are folk on here with all sorts of different backgrounds and skill levels and I'm sure this will help a few of them that may be considering a lathe.
Is your lathe like this? http://www.aliexpress.com/item/Brand-New-Watchmaker-Precision-Lathe-Basic-Machine/32262001583.html
I didn't mentioned before, but I had estimated the total cost for a complete system to be exactly what you wrote, but before shipping and customs (very high in EU). However it would be simply a not justifiable purchase for me unless I was to use it at least once a week, for productive work, and at this time I don't even know how to use it.
What could make more sense http://www.aliexpress.com/item/All-metal-mini-Lathe-Z20002M-metal-lathe-mini-metal-lathe-for-6in1-8in1-kit-29W-20000rpm/32364704636.html
Very, very interesting, many types to chose from.
Edited by jdm
Just now, oldhippy said:
Remember a lathe is a precision tool. Ask yourself what you intend to use it for, do a lot of research to find out if it is suitable for what you want. Don't forget some lathes have a better accuracy then others.
I think in watchmaking we pretty much want all the same, work on small parts with high precision. Do you have any actual recommendation? Specific makers or types?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
