Finally got myself a starter lathe
SSTEEL
It was gifted to me by a good friend of mine, its a Emco Unimat PC Lathe, needs tidying/restoring, so may do a guide on restoration on this like I did with my Elma cleaner.
Onto the photos.
27262591960_927f18c2f2_k.jpgShould clean up nicely by Micky Aldridge, on Flickr
26930687923_decde91fd2_k.jpgToe dipper into Lathing by Micky Aldridge, on Flickr
27466832811_dce537b705_k.jpgWIP Lathe by Micky Aldridge, on Flickr
Already started looking for accessories for it :)
These lathes are fine for clock work big enough to take Longcase clock parts. I think it might be a  unimat 4. I know there are loads of attachments fir the unimat 3 which I had, you will need to check to see if they are compatible. No good for watch work.
Excellent Micky and congratulations on a new super tool! Me too, -- like Geo -- I'm looking forward to your walkthrough and experiences. In my particular case, I've never had a lathe of my own and might get one soon...once I decide which! There are sooo many options out there...and prices! :)
This would be an invaluable experience to share!
Cheers,
Bob
That is a unimat 3 PC . One which you can  attach to a computer . There are lots of parts for it on Ebay. I recommend new o-rings for the drive pulleys.
I have a ordinary Unimat 3 which i bought back in the 80' . Still working good.
There are a lot of parts available for it? Like collets chuck and tool rest .
Edited by rogart63
Like many other tools, a lathe choice is a series of trade offs. As a lathe becomes larger and more powerful, the element of "feel" is reduced. If "feel" is not required to produce your part, as in larger clock size parts, a larger, more powerful lathe can be a great advantage. For a tiny part, such as a watch pivot (.1mm or .004 inches in diameter) the elements of increased machine mass and power become superfluous. A set of watchmaker turns powered with a hand driven bow can provide enough machine mass and power to produce high precision watch pivots
In addition to size and power, a lathe must also have sufficient precision to produce a part to a specified tolerance. The industry standard Geneva and American WW pattern lathes have sufficient precision to produce small watch parts.  Precision, however,  should not be confused with smaller size as there are many large lathes that are more precise than a standard watchmaker lathe.
david
JDM,
If you are going to machine a watch case out of a stainless steel blank, you will quickly appreciate a larger, more powerful lathe. The inside of the case can be cored out with an endmill or specially sharpened large diameter drill bit and finished out with a boring bar. If the job was done on a smaller lathe it would  have to be picked away with smaller, lighter cuts.  This is where the tradeoff comes in. If you were to try to core out the blank on a Geneva size lathe, the job would push the lathe past the point for which it was designed. All of this has to do with issues such as budget, shop space and available tooling that everybody should consider when selecting equipment. At the very least the machine selected should be able to handle the range of parts and materials that you plan to produce.
david
No, I would just need to level off corrosion on the seal seat there or on the case back. Any specific brand or model recommendation?
JDM,
A number of years ago I purchased a SINCERE lathe from China. It is a Geneva style light duty lathe roughly patterned after the Bergeon, Lorch, Wolf Jahn Geneva style lathes. When I bought  the lathe, including the cross slide and collet holding tailstock, the cost was around $450.00. The motor was an additional $200.00.  I later purchased the milling attachment,  spring pulley assembly,  dividing plate assembly,  sensitive drilling kit,  tip over rest, file rest and the extra long bed. In all everything came to around $2000.00. Once I took the spindle out, cleaned it, lubricated it,  installed an O-Ring seamless belt, and adjusted it, the spindle run out was almost undetectable. It is a fine high precision watchmaker lathe that produces a beautiful turned finish. That said, it is a small light duty machine that is not suited for heavy duty use. As long as the machine is used for small watch size parts and not pushed hard, it should provide many years of service. The swing is the same as other watch lathes and should be able to take a light clean up cut on a watch case.
Aside from being a good quality machine, what makes the Sincere lathe a good choice over other watchmaker lathes is its affordability, and the fact that the accessories are also affordable and available.  As long as the machine is used to take light cuts with small cutters and drills it should function beautifully.
david
Welcome to the forum David, and thank you for starting off by posting quality information regarding lathes.  There are folk on here with all sorts of different backgrounds and skill levels and I'm sure this will help a few of them that may be considering a lathe.
Is your lathe like this? http://www.aliexpress.com/item/Brand-New-Watchmaker-Precision-Lathe-Basic-Machine/32262001583.html
I didn't mentioned before, but I had estimated the total cost for a complete system to be exactly what you wrote, but before shipping and customs (very high in EU). However it would be simply a not justifiable purchase for me unless I was to use it at least once a week, for productive work, and at this time I don't even know how to use it.
What could make more sense http://www.aliexpress.com/item/All-metal-mini-Lathe-Z20002M-metal-lathe-mini-metal-lathe-for-6in1-8in1-kit-29W-20000rpm/32364704636.html
Very, very interesting, many types to chose from.
Edited by jdm
Just now, oldhippy said:
Remember a lathe is a precision tool. Ask yourself what you intend to use it for, do a lot of research to find out if it is suitable for what you want. Don't forget some lathes have a better accuracy then others.
I think in watchmaking we pretty much want all the same, work on small parts with high precision. Do you have any actual recommendation? Specific makers or types?
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
