Hello from Sussex
Hello and welcome from me. So how long have you been an apprentice and what stages are you at with watches and how far have you got with clocks. I'm asking this as many years ago that's what I did and eventually ended up restoring the better antique clacks.
I've been an apprentice for almost two years. I'm technically doing a clock pathway course, with my dad teaching me being a clockmaker himself. I'm on striking clocks at the moment. Watches I'm a bit more self taught! Only really working on manual wind watches at the moment, doing an automatic watch course in a few months! I'd definitely like to be working on the high end antiques but I'll work through the rest first ;)
Striking clocks I expect you started on something like a smiths mantle 8 day strike. Are you up to french strikes and carriage clock strikes. I went from that sort on to chiming clocks, you wait until you get to grandfather clocks. So if your dad is teaching you I expect you are using all of his tools including his lathe. I did a 5 year apprenticeship then 2 years as an improver.
Spot on! I'm due to start on French striking work within the next month (after my exams next week), carriage clocks there after im assuming. Yeah we have a couple of lathes here, a Cowells 90CW and a Unimat for clock work and I was also fortunate enough to have been left a Lorche 6mm watchmakers lathe buy an old watchmaker we knew well. 5 years is what my Dad did but mine is technically 3 years, although I very much doubt I'll know enough by then!
I had a unimat 3 for all my clock work and I found it to be very good, also a Boley for watch work. French movements are fine movements to work on and very good time keepers. Good luck with the exams let us know how you get on.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
