Guys, I fixed the crown, I simply pushed the clutch inside the crown and then pinched the outer part with tongs (pliers, whatever it's called), now it has less spring action but at least it won't split from the clutch and I can pull it out to set the date with no problem.
Edited by chriz74
So, awkward situation here. The new original stem arrived and it's longer than the one that was originally fitted.
Now I am asking myself, should I use the old one or try to cut the new one and take the risk to ruin it?
... I made the stupidest thing. Cut the new one without trying it before and now even if it's the same length as the old one for some reason it wouldn't hold the first position, the winding position like if it was too short. Could it be that the old one was not screwed completely?
update: So after cutting the damn stem I tried like this, put the threadlocker on it then screw the crown only half and let it rest for some minutes. Then I installed the whole thing and now I can set the time and wind the watch. Sometimes the stem disengages from the winding mechanism, don't know why. Anyway the watch was not running so I touched the balance wheel and it started to run, now it's running. I put it on the winder to monitor the behavior and see if it stops again.
I don't know if the stem solution was the best thing to do, probably not, but it kind of worked and I don't want to spend 25 euros for a new stem right now, not before seeing what happens.
Edited by chriz74
Expand
Please measure distance E. Seems different to me.
Expand
No, it's the photo angle, it seemed to me too but looking closely they are the same. This is an original rolex 7869 stem. Besides I ended up putting the old one.
Edited by chriz74
Here we go, after 49 hours on the winder I found the watch stopped. I moved it a bit and started moving again. Now I stopped the winder to see when it will stop again, the problem doesn't seem related to the automatic winding. Maybe there's something, some debris that is stopping the movement?
Edited by chriz74
If the watch is stopping and starting I would say it needs at least a clean. As for the stem it could be a matter that dirt has got under a part and is causing the problem, or the old stem has worn somewhere on the shoulders.  You say it does the same with the new stem so there might be wear around the entrance for the stem to go into or it could be dirt, does the stem wiggle around when the stem is in the winding position and in the setting of the hands position, if yes is the answer to one or both this can be fixed by a pro who knows what he is doing but it is very hard.
Regarding fitting the stem, Hippy is correct regarding cleanliness of the crown and pendant tube.  Once you ensure all is spotless, have a read of this article on stem fitting
You will find a post specifically on screw down crowns later in the article.
Took the watch to the guy that originally made the servicing. He said he had to lubricate the invertors of the automatic device. He added something about Rolex telling these don't need lubrication but he thinks differently. Let's see if the watch will stop again.
Normally when a watch keeps stopping then the watch just needs a complete service & clean. I would personally take the watch to another watch repairer for a second opinion.
  On 7/11/2016 at 4:57 AM, chriz74 said:
Watch stopped again. Invertors are not the cause.
Expand
What on earth are invertors. To me it sounds as if he doesn't know what he is talking about. Is he qualified to undertake Rolex repairs.
Expand
I think it's referring to the mechanism that takes care of rotor change of direction.
Expand
I would do as clockboy has said.
This morning I wound it manually and put it on a winder. Let's see if it stops. I'm thinking maybe yesterday stopped because after getting it back I didn't wound it and had it only for 3 Hours the day before on arm.
Watch stopped again after 48 hours being on the winder. I suspect the rotor is maybe slightly touching the caseback hence not winding correctly. So now I unscrewed the back as much as possible, gave 4 wounds and put it back on the winder. Let's see if it stops.
ok, watch stopped again, so it's not a caseback problem. I opened it once stopped and found this, isn't it strange that it remains stopped with the balance spring closed like that?
Any chance that it has got magnetised somehow . My wife works on a computer all day and I often have to demagnify her auto watch . It never actually stops but runs very erratically .
    • Sorry, no - these are the real model 987801; stainless steel with a white and blue (or black?) dial: https://www.chrono24.co.uk/cartier/ref-987901.htm
    • Though I mostly do vintage I can’t say I’ve benefitted greatly from any company’s technical documents. Is anything in them infinitely superior to WOSTEP or AWCI? Maybe knowing details of purple winding gears and I guess epilame on all those other parts is fun…I still pull them and read when I can fine them I suppose 🧐…
    • One of the blessings of being an enthusiast is that I can spend whatever time I need on a watch to make it work as well as I can. Before I take on anyone's watch, I always tell them that I can't promise anything about how long it may take and what costs it might bring. Of course, any additional costs must be agreed upon. As you indicate, it's only when you're done that you know for a fact what time was required and the cost. It's the same pattern as with any complex undertaking, and repairing watches can be complex, even very complex. No, far from it. The secrecy from the big brands is honestly one of the most frustrating parts of this hobby. Even when you do manage to get hold of service manuals, they’re often missing crucial details—things like lubrication points or even just the safest way to disassemble and assemble certain components. Luckily, WRT exist, and over time you build up the knowledge and experience to work around the gaps. Sharing tips and hard-earned tricks here makes a huge difference. The secrecy itself seems to be part of the business model. Take the Rolex 3135 as an example—rather than clearly explaining how to safely remove the date ring in publicly available documentation, Rolex sells pricey training programs and certifications to their authorised service centres. And who ends up paying for that in the end? The customers, because independent watchmakers and passionate amateurs are pushed out. It’s a shame, really. If the car industry operated like this, the backlash would be huge.
    • Provided the tool is in good condition, and hasn’t been subject to dodgy repairs (some I’ve seen on eBay are in terrible condition or were incompetently repaired) the balance arms are clamped very securely when performing adjustments and the relevant surfaces are true.  This is an excellent tool in my experience.  Here’s a picture of a balance clamped securely, ready for an adjustment to be made : Best Regards, Mark
    • I don't use a lathe to reduce the diameter of the pin I use something else but I'm a bit puzzled as to why is it too big in this particular case is that's extremely big? By some chances as the balance bridge off another watch?
