Vintage watchmaker tools - how to use them
DGW
I'm rather new to the watchmaker world and more focused on the larger pocket watch movements.  As I look for the older vintage tools, I get confused on just how some of these tools were used.  Does anyone know where to find videos demonstrating how the vintage watchmaker tools were used?  Thank you!
If you post some pictures of tools you have seen, I am sure between us all we could have a good (or bad) guess at what they are for, if you don't know what they are for it will be difficult to find a video explaining it.
Edited by Tiktok
I would also like to see the tools.  I prefer to read a book - there is a very good one on the subject of "watch tools"  I can look it up.  pocket  watches are a great place to start  "watch making". I  have found the two main problems are obtaining a crystal and corrosion in the stem. "keep up the good work".  vinn
Posted some photos.  Thank you
DGW, the last picture relate to the jewels. Some sort of expansion tools to close and/or open the hole where they go...it is in the forum somewhere. The 3rd picture up from the bottom, is a depth gauge if I'm not mistaken...
Now, I have no idea about the rest and honestly I haven't even tried or used any of the tools you have posted...I would use the center tool in the first picture to bury a watch that is giving me a headache! :)
Sorry I can't say much about those...but don't dismay, our experts will soon lift the mystery!
Cheers,
Bob
Following is what they are as far as I can tell. You should then be able to find information on using them.
1st photo:
1. Combination tool, used for a number of jobs. See instructions at the bottom of this page http://www.watchpartsandtools.com/JewelSetting.html
2. Pallet warmer, one of the above jobs
3. A type of screw head polishing tool
2nd photo: Not really sure, looks like some type of pivot straightening tool. Appears to be lacking a means to turn it
3rd photo: A bow mill or bow milling tool. Used in the fitting of pocket watch bows
4th photo: Jewelling tools, for either opening or closing Jewel settings
Stephen
No. 3 in the first photo is a handle with a set of three lantern chucks for holding screws of different sizes to allow trimming, finishing and polishing the ends of screws.  It is nothing to do with polishing the heads.
Thanks for that - I've never used it but that's what I was told it was for. To be honest I did wonder how you were supposed to keep the screw level ;)!
Quote
timing screw holders sounds right.  part of an antique  method of balancing by moving small  screws the balance wheel.  not used on modern watches.  probably a valuable antique.  the pallet  warmer you will use.    thanks for the photos.
On EBay people often put quite odd descriptions of items - presumably they've no idea what they are and just put something they think sounds good.
This one for example :http://www.ebay.co.uk/itm/Movement-Holder-Ref-5362-/252356832437?hash=item3ac1a3acb5:g:gxQAAOSwHQ9WYH6s
I've actually written to them to tell them it's a roller remover, but they never responded and never changed the listing. What makes it worse is that they are actually a horological supply company.
I'm glad I got a reaction on this because I don't think its right, but what it does give us is other pictures of this thing and how it might work. So I did a  little investigating and found this video and it is a bow pivoting tool.
Edited by oldhippy
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
