When I stumbled upon this Trias watch on the bay a while ago now (Seller has been having trouble selling it for a while as I have seen it on there for months), I was intrigued, it has a Swiss ETA 2836-2 movement fitted, however, instead of the two popular, and well known complications, Date, and Day, this also has, 24h, Month, Daylight/Night(moon/sun), two pushers crown side, and a push button @8 o'clock position.  I was really curious, so purchased it.  I plan on dissecting it to give it a service, and will be interesting to see how all these complications reside on a 2836 movement.
Here are some photos.
25948169244_ed59397d83_h.jpgTrias1 by Micky Aldridge, on Flickr
26527138486_3454860c1b_h.jpgTrias3 by Micky Aldridge, on Flickr
26553145835_62e7b7945a_h.jpgTrias4 by Micky Aldridge, on Flickr
25948168594_ec72422fa9_h.jpgTrias5 by Micky Aldridge, on Flickr
25950233513_c75bde3434_h.jpgTrias6 by Micky Aldridge, on Flickr
And a photo of the user manual.
25948168144_afd2684881_h.jpgTrias7 by Micky Aldridge, on Flickr
Anyone else come across an ETA 2836 with these complications before?
Me too, I may enjoy wearing it for a little while to see if I like it, either way, I will be stripping it down to inspect those complications, sure has me intrigued.
That's nice I look forward to seeing the movement and all its complications. Time to charge that camera methinks:D
Whats more confusing is the user manual starts 21,600bph, and 35 jewels, obviously those extra jewels must play a part in those extra complications, but why low beat 21,600bph when an ETA 2836-2 is high beat, 28,800bph?
"germany" is also engraved on the back. i would have thought that it would have said switzerland.
that's a really cool watch, i'd own that one.
4 hours ago, frenchie said:
Looking forward to the walkthrough!!!!
Is there an empty screw hole (under the word "watch" on the back)?
I don't think the empty screw hole is particularly unusual - I've seen that on a number of movements when in situ. Much depends on the case style being used for the movement.
On the other hand...
I was thinking the exact same thing, time to throw that onto the Timegrapher! :D
Nice find:)
Edited by jeffc83
Hadn't noticed that screw hole, I will inspect and find out how the movement is secured to the case.
Will also put the watch on the timegrapher when it arrives, and post the results.
Hi Micky,
That's an interesting find...would it be some 2836 made by another company? i.e. could be a sellita or some similar...or even copied by the German company with some mods to accommodate the complications...
It is really going to be an excellent post when you can report back with your findings...and looking forward to a walkthrough!
Cheers,
Bob
And its landed, the first thing I did was check it on the timegrapher, its a high beat ETA 2836-2, 28,800bph.
The Amplitude, sec/day and Beat Error were not readable, worst ETA movement reading Ive seen, I guess those complications take their toll on its performance.
Looking forward to tearing it down, but work calls, snowed under, so if you are waiting on me dissecting this unusual watch, then bare with me :)
I will bear with you Micky, but definitely NOT bare with you! :D Just couldn't resist!
About that movement, it is getting more and more interesting. The mystery is keeping me on the edge of the seat! No, seriously, I'm very curious about this mod I've never seen or head of before!
Cheers,
Bob
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
