Custom Watch Timing Stand
jdrichard
instead of a pin for the level, you could make the top part of the stand bigger around the axis point.  Drill small countersinks on the "in" side at the 12,3,6,9 positions and have a spring-loaded pin in the aluminum to interface with the countersink/detents.  This would provide a positive engagement at the 4 main positions without requiring any fiddling with pins to move into or out of the horizontal position.
I think my only option at the moment is "rubber bands" to hold the movement in place. The other idea would be to devise a clamp that would blanket over the movement?
From Canada
From Canada
4 hours ago, jdrichard said:
I need you to sketch this out. I'm an engineer and need pictures, words just confuse me.
From Canada
something like this:
the "detent ring" would be on the stand and the lower part he doesn't adjust would be the AL holder.
A clamp only needs one moving part.and a fixed base - if you use the same shape the regular ones use, i.e. little "C" shapes that cup the sides.  You could use pins and get away with w fixed and one moving.  the movement could be adapted from the various movement holders.  Put the two fixed pins at 10 & 2 and have the moveable one at 6.  One immediate complication that springs to mind is making it band-compatible.
Thanks. I will investigate tonight and get back.
i suck at drawing.  your stand device has two parts: the stand part and the movement/watch holder part.
on the movement holder, source a spring that fits in the hole you've already drilled in it and a ball bearing that's a tight fit.  jam the ball bearing over the spring and stake it into place.  the spring needs to be long/strong enough to push the ball bearing out at rest.  As you rotate the movement holder about its axis, the ball bearing now describes a circle on the stand.
you now need something that is a dupe of the click ring in the video, the little brass disc he's holding.  you would have 4 divots if you want 90* turns; 8 if you want 45* like in the video.  You need the divots at the specific radius described by the ball bearing.
you could machine a separate disk and pin it (like a dial) into the stand piece.  or epoxy it.  or create a new stand altogether with the divots integrated.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service.
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
