New member saying hello
VDRKO
I thought I'd take a minute and introduce myself.  I've always been fond of watches, but recently had the opportunity to take one apart and fix it (replaced a wheel with a broken pivot).  I have a couple beat up Seiko 7S26 movements coming my way in the mail and will take those apart and put them back together a few times to make sure I know what I'm doing.  My goal is to be able to buy vintage automatic watches with mechanical issues and return them to service.  I look forward to chatting with the forum in the future!  Best regards - James
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
