Your favourite music thread.
I'm still on 4.9.5
Didn't upgrade as so many bad reviews every time an update came out.
Worked perfectly until the forum update.
IPBoard 3 will lose all support, including security patches by next year. I had to upgrade to IPBoard 4.
And this involved updating the Tapatalk plugin to the latest version.
There's no getting away from it - at some point you will need to upgrade your Tapatalk client.
In terms of bad reviews - my Tapatalk client is the latest update from the iOS App Store and I'm having no more problems than before. I have always found Tapatalk to be buggy and glitchy from time to time, but for the most part, fairly stable.
Thanks Mark.
I have always resisted uodating apps if they ain't broken. Also, having read people complaining about intrusive ads makes me even more hesitant.
50 minutes ago, ro63rto said:
Thanks Mark.
I see where you are coming from, which is why I resisted updating IP Board to v4 for so long. And my Mac is still running Mavericks because I don't want things to break should I upgrade, and Yosemite and El Capitan are free lol.
The ads in the Tapatalk client are a slight annoyance, I am considering paying the 79p myself to have them removed from my app.
"Hector the Hero" - on solo tenor guitar
I've been working on a lovely lament by the Victorian Scottish composer, James Scott-Skinner to commemorate the death of a  legendary Scottish soldier, Major General Sir Hector Archibald MacDonald, KCB, DSO (1853-1903), known to everyone as Fighting Mac. MacDonald, the son of a crofter, rose rapidly from the ranks to become a Major General, fighting in campaigns in the Middle and Far East. Jealousy of the fame and popularity of a down-to-earth, lowly-born soldier in the upper class ranks of the army led to rumours of homosexual behaviour in Ceylon - never really clarified. MacDonald was in Paris in 1903, en route back to Ceylon, and shot himself. A tragic end for a gallant man, demonstrating the attitudes of the establishment of the time.
The MS of the score is labelled "coronach" - a keening or improvised singing at a death. I've chosen to treat this piece a bit in the style of a pipe lament with no backing chords - just the melody played more or less in slow march time - twice through. In the (written) key of A on the tenor guitar (G voicing, capo'ed on the 2nd fret to get the open strings). I've added some grace notes here and there - and tolled the bell for Hector at the end of the piece.
Hector the Hero
  • 7 months later...
I like to listen to a variety of music and I've really enjoyed all (or most) of the selections here... I'm going to try to add to the collection with one that I've enjoyed lately.  It's one that is both haunting and uplifting, if you can imagine that combination.  It's from David Lanz and it's called "The Green Man"  Hope you enjoy it...
Hector the Hero
Really nice, melancholy little piece.  Thanks for sharing...
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!?
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
