Left Or Right? Seiko 6309
This screw on a Seiko 6309. For the date wheel . Is it left or right handed? It sits hard so i am afraid to strip the tread or brake the screw. If i turn the wrong direction.
Edited by rogart63
What do you gain from removing the wheel anyway? Being plastic it takes no lubrication.
If I remember correctly it is a regular screw. They are usually hard because of the plastic wheel they are into....but proceed with care!
Could have done that? But thanks to Bob i manage to remove it. Plick it said :) Just wanted to clean everything and make sure nothing is damaged.
That is a great intention until it happens that something which could have been left alone gets damaged this way.
It would be normal, the other way has more then a single slot something like 3 or 4.
Unfortunately this is not always the case OH, I've had a few lefties with single slot. These are usually in the winding mechanism where high torques are involved could possibly unwind the screw.
In this case being a date driving wheel that has little or no torque to talk of, I would suspect it will be a normal right hand thread.
It would be correct to remove the plastic gear in order to clean the mainplate properly. Basically anything which can be removed should be removed.
Plastic gears need no lubrication but how do you know if the previous guy didn't oil it? You also need to check the gears, not only the teeth but the 'hole' and the area it rubs on the mainplate.
Plastic gears should not be cleaned in cleaning solutions. Rodico will usually clean it right up.
Anil
Anil
A perfect answer.
    • An update to my post above, i got this type of bezel remover yesterday, absolutely perfect, the build quality is very good, no slop or play, perfectly aligned, no manufacturing defects, i've tried it on a couple bezels and it just works how it should, it's a solid bit of kit, i'm more than impressed. The scores on the door say it's a 10 out of 10 from me. What a difference in build quality from the first bezel remover i got, i slagged the first bezel remover off as chinese junk but this one makes up for it.
    • Hi, I am looking for some Seiko Diafix cap stones. Managed to play tiddlywinks with one.    Seiko part number 011221
    • I remembered that when Lititz Watch Technicum's YouTube channel existed, they had a video about polishing. As I recall, many experts thought that video was among the best on the subject of polishing. It's a real shame that their videos are no longer available and I've been in touch with them regularly to see if they can get these videos back. Unfortunately, it seems that these videos are gone forever. The last message I received from them on 21 January read: "I'm sorry, but not yet. In a nutshell: the school is scheduled to be shut down next year - a new school is bring opened in Dallas, Texas. Because of that all video access is blocked. If a decision is made to not close the school, then at some point the videos will likely be made available. We just do not know that yet. So, just check in again in a month or three; sorry I can't be more specific than that." Well, as I recall, there was a section in the video that was about how to preserve the edges of a watch case, that is, how to avoid rounding off the edges when using a mop wheel. I don't remember all the details but what I do remember is that it's about keeping a high speed on the mop wheel and keeping a light pressure on it. I didn't think of this when I was polishing the case back but the next time I'll try it and see what difference it makes.
    • Good idea, I  was thinking of something similar but using a drill press.  Apologies, all the other comments have just appeared.  I was replying to @HectorLooi , the chain pusher is a good idea too.
