Watch Crystal Polishing
Is it possible to get scratches out of a Seiko Hardlex Crystal. I tried with a drumel tool and various types of polish but was unsuccessful. Polishing the body of the watch works well, but the darn crystal scratches stay. You would think that making a scratch is less violent than 5000 rpm drumel with #2 polish.
From Canada
I think Hardlex clouds with the heat of the dremmel...too fast, too hot! By the time you "eliminate" the scratch the crystal will be unusable. A slower "way/machine" with gradually decreasing grids and, using a coolant, might work though.
It can be done as I did one for my 6139B for which new Seiko crystals are hard to come by a very expensive.  Just needs plenty of patience and work through the wet&dry papers, then diamond pastes to get the final polish.  Mine took about 4 hours in total so maybe not cost effective for a pro.
I got about halfway through and decided that as it was a nice sunny day (1 one we had last year) I would continue on the patio.  You guessed it, just about to give it a final polish when I dropped it, and yes it broke into 3 pieces.  I nearly cried !!
Just had to cough up for a new one but settled for a Sternkraus which was a perfect fit.
Edited by canthus
I have polished one yesterday, no big dial. Speed can be 6 - 10K, doesn't matter much, paper quality do matter. I've found that most effective is 3M 600 grit, wet of course. Finish with 2000 and if you have it diamantine paste.
One or two darn specs of dust have dodged my attention and I'll remove them tomorrow.
Did you use a Drumel tool and some sort of bit?
Rotation speeds implies a rotary tool of your liking and wet paper about 6cm diameter. People saying it can be done manually just love to see their life being ground slowly.
Edited by jdm
If you had kept going with the 2000 grit before the final polish you would have removed all the marks from the 240.
I did finish with the 2000 grit but did a final buff with Peek. I think a piece of leather would work as the final final buff
I did see some very fine scratches if I looked at a light through the Crystal. I'm pretty picky so I did do a rebuff with the drumel and some fine Green #7 polish. Looks pretty good now. Like new. Now I don't have to disassemble the Crystal assemble including Gaskets etc.
Awesome video dude!! Exactly what I was looking for in terms of polishing info!
Thank You
Hey thanks. The video I did is what I was looking for all along. I have a ton on YouTube music and some magic videos but now am adding Watch Repair instruction where I can and only if it works. Mark is the man when it comes to the watch repair game. I am one step below amateur. You can find me on Facebook as well under JDWatchboy. I put up the site to track progress on some watches I am fixing for friends and for part costs only. Just enjoying the hobby, but who knows?
Ok, revised advice. I took the Crystal once again as there were two small hairline scratches that were just bugging me, and tried to remove them using pumice. That made it worse. Then I used my drumel again and tried to buff out the new scratches; that didn't work. Then I got out the 1200 grit and worked a full sheet of rubbing followed by the 2000 grit and a half sheet of rubbing; THAT WORKED! So new technique should be Drumel with 240 grit drum for the first shooting and major scratches followed by a quick drumel buff with number 6 High Gloss, followed by 1200 grit, Two Sheets of hand rubbing and 2000 Grit 1 sheet of hand rubbing (sanding). DO NOT GO IN CIRCLES while rubbing; back and forth is best. Thanks.c57d3bc465bd728e67c60a8688664877.jpgc80a5f8af13ad56d65617b4a571299ad.jpg
i gotta tell you that is an excellent job. it looks like a new crystal. i just purchased a seiko diver that needs a lot of help with the crystal. i am actually gonna buy a new one, but i'd be interested in trying this method on this crystal. the diver i got has quite a few deep scratches that i think might not polish out.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
