I wear glasses  and have done from the age of 4. When it came to using an eye glass at work I would take my glasses off because my left eye is near perfect and that's the eye which had the eye glass. I couldn't get used to glasses and eye glass.
Sometimes you just don't know which side. One day, I tried to learn playing golf. First thing you get is a set right-handed clubs, and the instructor teaches you how to swing right-handed etc. Not knowing better, you try to adapt and learn. Initially you don't hit the ball anyway, so it doesn't matter :). Then I became aware of the existence of left-handed clubs.
The instructor found some dusty left-handed clubs, a bit too short for me. I tried those and to the annoyment of the instructor, I just couldn't make up my mind.  Long story short, I ended up with right-handed, probably due to availability and both sides play were equally poor :)
Edited by Endeavor
I am sure I have seen gravers for left hand use i.e. the angle of cut is different. If you find a lathe that can be run in inverse you could turn the lathe around so the tailstock is facing on the left. However if it has a cross slide then you are snookered. I am sure there are many operators that are left handed and have just adapted. My son is left handed and has used my lathe with no issues.
I was taught on a "normal" lath and learned the skills........never thought about it and never had an issue...... one of those things you grow into I suppose..
In the work-houses back in the day, watchmakers had to sit at benches very close to each other..one lefty will be forever banging elbows with his partner o. The left!
I'm just joking ! I'm half Chinese and at a Chinese dinner its impossible to eat with chopsticks if you're seated next to a lefty...it gets quite cosy at some dinners!
Anil
Ohhh...if anyone wants to make a left-handed wrist watch, look for one powered by an eta1256. The dial feet are symmetrical so you can flip it 180degrees and instantly have a watch with the crown on the left!
Anil
I am also left handed,
Chainstay,  "the lefty often has a lot more precision and dexterity (oddly enough given the meaning of "dexter"...) than average"
Unfortunately I must be the except to the rule
:D i am also a lefty. and i also heard that saying.
I'm left handed but do a lot of things with my right hand.  My right eye is my dominant eye so I hold my pistol and shoot with my right hand.  Most of the type I use my eye loupe with my right eye though, again, I find I can almost use it as effectively with my left.  I also use my right hand for lathe work.  I find that for almost every thing, except writing and tying my shoes, I'm basically ambidextrous.  My watch instructor encourages us to be facile with both hands.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
