Rolex 3135 Beat Error Adjustment
clockboy
Hi Guys, I have a question re-beat error for a Rolex 3135.
Last year I serviced my Rolex 3135 all was great apart from when I put it on my timographer it showed dial up
NO error 0 +/-
BUT it did show a beat error of 1.4 ms. & I could not see how to adjust so I didn,t & it has run great.
However there is something amiss with the auto side so I need to re-address this. I am going to use Epilame fixodrop on the reversing wheels before l lube this time
BUT
While the watch is apart I would like to adjust the beat error anyone know how !!!!
If there is no adjustment lever for this I would think you will have to re-position the hairspring relative to the balance, or re-position the roller table relative to the hairspring. If the watch is starting OK and keeping time as well as you say........leave it alone!
The,s my thoughts also. However I do find it strange, that you can adjust the time via micr-stella screws you can even just the end shake but there appears no easy or accurate way to adjust the beat. For a high end quality watch very strange.
Intersting suggestion from a member (Endevor) suggesting this might be how it,s adjusted see pic. If I undo this screw can I twist the whole unit?  The screws on the ends are to secure the balance & underneath are the adjusters for the end shake.
I'm not at all familiar with this movement CB, there does seen to be some interesting adjustments available. I don't think you will be able to rotate the whole bridge, there appears to be adjusters under the bridge at each end that might be for end shake adjustment.
That said, if the mounting screws are equidistant from the balance axis, and these adjusters are eccentric then you might be able to rotate the whole bridge to adjust the beat. If this is the case, you would have to adjust each one identically to ensure you didn't knock the axis out of alignment.
Thanks Geo I think the same actually. The screws on the ends are to secure the balance with adjusters underneath to adjust the end shake.
With these adjustments I just find it hard to believe no adjustment is available for the beat Omega etc all have adjustments so why not Rolex.
I might give M a PM if no progress
Hello Clockboy; Not sure whether we are talking the same, perhaps we do, but I like to explain it in my Dutch/Dan-English.....
It seems to me that the screw with the arrow holds down a bracket. The end of the bracket (the left hand-side of the bracket) clamps down the "center" of the balance-bridge, there where the Incabloc is. I haven't undone this screw, so I do not not know if it's eccentric.
Anyhow, my suspicion is that if you slack of the bracket / clamp, you can adjust the "begin" position of the hair-spring.
I have my movement still out of the case and the beat error is around 1.5 to 2ms. If there are a lot of "heads up", I may give it a try........ after I build it in that is.
Edited by Endeavor
Thanks, strange that we both seem to have the error. What I will say although my Rolex has an error of 1.4ms it runs great and keeps excellent time. I will do some more research & may have a play when I do strip the watch. i just can not believe a quality watch such as a Rolex does not have an adjustment or are they set at the Rolex factory and deemed never to be adjusted.
Guys, maybe the movement is so good that Rolex sold it "in error"? :)
You know, as in "both with the same error", oh, come on, a little smile! :)
In an more serious vein, what Roland says makes sense and I agree with CB about all the adjustments available except that important one...I guess I'm learning along this thread!
Cheers,
Bob
Thanks Bob just wondering if Endeavor has spotted the adjustment. If the screw I have arrowed is concentric then that will be it. I have a couple of jobs arrived today (non running french marble clock & non running Seiko Quartz) so I will tackle them first just too get my hand & eye,s back in the groove before the Rolex.
Not hampered by any knowledge, I can still afford stupid remarks......
My training watch was a Swizz ETA2540, see picture
post-1663-0-91987400-1455548524_thumb.jp
You can see that on top of the balance are two "levers". Completly on top, the black one, is to set the daily-rate, the other silver shiny one, with the screw & holder for the hair-spring, which can also turn, is to set the beat. I've been playing with this (a lot) to get my ETA2540 in beat and the daily rate as accurate as possible.
When I saw the 3135, my direct assumption was that the Rolex, being Swizz, had the same arrangement / setup, the only difference being that it had a clamp/bracket on top to "lock" the "beat-lever".
With the ETA2540 it all was a bit tricky because once you move the beat lever, the daily-rate changes. If you change the daily-rate, the beat changes. It was a bit of a chicken / egg game.
If the Rolex has the same "beat-lever" idea, it is not interconnected with the daily rate and therefor easy to adjust.......
Would be nice if Mark can confirm this, as I was planning to "fiddle" with it..........
Maybe I'm too simple here?
Edited by Endeavor
If the Rolex has the same "beat-lever" idea, it is not interconnected with the daily rate and therefor is easy to adjust.......
Maybe your right I have corrected many watch beats either by moving the hairspring or adjusting as the ETA. Watch  this space !!!!
Could you please explain how it worksJDM?
I have no direct experience but as mentioned it looks like the screw head drives an eccentric that rotates the hairspring stud arm. Very elegant, safe and accurate solution.
Edited by jdm
Thanks JDM........ it may / could well be......
However, I think that's a bit too "sophisticated" for a Rolex. Meaning that I had the impression that Rolex likes "KISS".
We'll seen next week what CB finds out, or if I get my one in its case, before that........
Perhaps Mark popped up while we were waiting to find out the truth?
I think that what you call KISS is better described (for Rolex at least) as "superlative engineering efficiency" . I don't believe for a moment that a Rolex movement does not allow beat error adjustment without taking the whole thing apart with waste of time and the risk of breaking things for good.
Anyway, you can see that the hairspring end stud is solid to the arm kept in place by the screw. All what it takes is a small movement to adjust the centering of balance assembly, Otherwise that screw has no reason to exist and all what one has to do is to just to push on the arm as on most uncrowned movements.
Edited by jdm
I guess the general consensus is that the beat error adjustment is to be found in the middle of the balance bridge. Whether the screw is indeed eccentric and moves the centering or it secures a"clamp" which prevents unwanted movement of the centering (in case of a drop), isn't that relevant.
The key to adjust the beat error sits in the screw or is directly related to........
I like the "superlative engineering efficiency", which seems just like KISS, often hard to achieve ;)
Edited by Endeavor
Beat error is adjusted rotating either the center or the end of the hairspring. Looking better I stand corrected, no eccentric is used, the screw tighten a small cock to clamp the stud arm in place. Beautiful.
From http://luxurytyme.com/movement/index.html
Difficult but doable. Famous examples... Porsche, NAD Hi-Fi.
That's a much better picture of the balance bridge JDM and you describe it in the correct terminology.
I'm sure CB, among others, will be very happy..........
Leaves me, as a novice, with the question whether I should adjust the beat error right now, or let it first run for a while?
Since the movement was unprotected, I placed it in save, but "undefined" positions on the microphone of the Watch-O-scope and had the following readings:
+ 3.2 s/d Amp 234 BE 1.6 ms
+ 8.1 s/d Amp 258 BE  2.2ms
+ 9.7 s/d Amp 253 BE 1.5ms
These readings were "good enough" for me to go ahead and fit the dial & hands. With the Dial Up it ran about +3 sec in 24 hours.
Before servicing, the BE measurements were about the same and it ran about +2 s/d on my wrist (day & night). The above readings do suggest that it runs (slightly) faster now.
In jdm's picture above the screw head holding the sub-bridge does not look centred on the hole. It's only slightly off, but could be just enough for fine adjustment if it's an eccentric. I would say it was worth a tweak.
    • Just picked this up earlier today. This find just about epitomizes vintage watch collecting for me and what really keeps me going. Hit 2 antique malls today and saw a couple of pieces at the first one but just nothing that I needed. At the second one saw a Accutron 218 but it was 20 minutes behind the actual time. These "malls" have numerous booths of a variety of sellers who likely go in once or twice a week. Considering that that watch should be within a couple of seconds a month, I figured it hadn't been phased so passed on that for now knowing it would need work to run correctly and the price tag. Then I found this Excelle in a display case. I never heard of the brand, but in was an auto and had a little heft. It turned out to be 40mm lug to lug, 35.3mm case width, and 12.3 mm thick. On the spiedel once size fits most flex band. At $10.80US with tax I immediately pulled the trigger with nothing to lose. Before pictures: I spent a nice 30 minutes taking it out of the case and running that through the ultra sonic replacing the crystal and gasket and recasing, but spent five minutes first getting it running close on the timegrapher. Had a new crystal already in stock. I probably could have sanbed and polished the old one, but for $3 there is nothing like a new acrylic that makes a watch pop, in my opinion. The caseback gasket was hardened and just glad it wasn't tar. Changed that as well. Here is the after Pic on a temp black strap while I decide on a leather or steel bracelet. An added bonus was doing some research and finding out the Elgin connection and the movement is a PUW 1563T which is German I am pretty sure and probably why it doesn't say Swiss made on the dial. This movement is supposed to have a hack feature and quickset date by pushing the crown. But neither of those complications seem to be working. Not sure if the stem is cut too short because there is no gap for the crown to move. Either way at some point will need to be serviced and check the keyless works to find out what is going on with the quickset and hack of the sweep second hand.
    • On the link that I posted, one of the watches has no crown and another has a crown that is not square to the case. Does a broken crown signify that the movement may be quite corroded, hence the stem has broken, and does the bent crown simply signify that the stem is bent? Unfortunately as the seller has a bid on the items, he is now reticent to prise the casebacks off in case he damages something. The seller did reply with this email though. Hi again Michael - brief descriptions; Oris x 2, dials and hands ok and they set ok and one I just wound and it has been running for a few of minutes as I write this response. Rocar, dial ok no crown. No name dial no good and can't pull crown out to set. Roma dial and hands ok, I think it is pin pallet movement. Unicorn, good dial and hands and plexiglass ok for age. All cases and plexiglasses show wear except as mentioned. I have no idea what movements are fitted or condition so please if you do consider bidding, please do so accordingly as I don't like to disappoint my customers - regards and thanks again for your interest - Jim
    • The incomplete Vertex DD is a new project to sort out.  The Seiko gen 1, is my favourite watch to wear and is my daily.
    • To be fair it was a beautiful 'bumper'.  But, there was some loose parts in the case.  Perhaps 'pig' was a bit excessive 😄.
