Some Bits
BeyondWorld
Atomic.
And on the back in french it says something like "though land, though sea, through the sky, to the moon!" on the back, which I think is kind of funny.
Probably my favourite watch to wear. It's a hard choice between the speedmaster and this one for me. Although I think everyone would probably go for the speedmaster.
post-1618-0-86204500-1454860256_thumb.pn
Hi B,
How big are they? Is the Cyma model still available somewhere?
Cheers,
Bob
Mine is 41 mm with the crown. 38 mm without.
They are around in England, and ebay, as being british military watches. They are from the 1940's so, I'm guessing you mean they are available second hand, and not like somewhere new in a shop. :-p
Wow. It's getting better and better the further down i go. Love the Lemania and the Eterna. And the Speedmaster with it's JB champion strap is wonderful. Looks like a 105.012 with the DON bezel or  maybe a 2998?  Congratulations you have a wonderful watch collection.
Thanks for sharing a very admirable sampling! I'm head over heels for the Eterna Telemetre. Do you have any additional information about it? I'd love to add that to my dream team search list.
Not much really, it's 1950's valjoux 22, oversized screwback, the case doesn't have any reference numbers. Apart from the case back saying it's anti-magnetic and waterproof. I've had the exact same watch in white dial though as well, so they are around.
Thanks,
Its a ST 105.013.
I don't know what DON bezel means haha, I'm not so good with the new terminology. But I'm pretty sure it's the original one.
DON means dot over ninety . The little dot that is next to the 90 . The later speedmasters have the dot next to the 90 . Like this?
DON bezel.
Dot next to 90
When Omega serviced the speedys they often changed the bezel. This makes the DON bezels worth a lot of money this days.
attachicon.gifDON ..jpgDON means dot over ninety . The little dot that is next to the 90 . The later speedmasters have the dot next to the 90 . Like this?
DON bezel.
Dot next to 90
Ah, gotcha. Yeah, I understand there's a difference between a service bezel and the original, never knew they called it a dot over ninety, interesting to know.
    • If you're seeking advice for your "Harvard GSD" MArch II application essays, I'd recommend taking a thoughtful approach. Reflect deeply on your experiences, passions, and goals, and tailor your essays to showcase your unique perspective and potential contributions to the program. As for resources, I recently stumbled upon a gret platform for essays, and I must say, it's been quite helpful. Their selection of pre-written essays covers a wide range of topics, and their professional writers can also assist with custom essays tailored to your specific needs. Check out their offerings here: https://essaypro.com/essays-for-sale. Remember, authenticity is key in your application essays. Good luck!
    • For clarity and ease of testing, I redid that diagram, flipping the circuit to match the layout of the physical watch.
    • Hello, Thanks for the reply. The old jewel will get pushed out from the "outside" which is the dial side. The new jewel will get pressed in from the inside (shown below) which is the movement side, correct?     And the old jewel and spring will get pushed from the is the "outside" which is the dial side. Thank you very much for the information. I will take out the KIF spring and save it. Will update when the new jewel is in place!   Regards, Joe
    • It's a little circlip style retaining clip to keep the pinion from riding up out of position.
