don't know if I will try the class or not . I didn't see a schedule of when the classes are taking place. so I am not sure if it would fit my work time or not .
No Daniel, there is no schedule, you take them when you can and as long as you can. Just visit the free sample lesson and you will understand what I mean. If you are spending that kind of money in tools and what not, might as well get the class I think. It is still a very personal decision though and I'm not associated to them in any way but I have learned a lot from them.
I've cleaned quite balances ultrasonically over the years without any problem. If in doubt, try it on an old movement first to see how you get on. The only thing I will not ultrasonically clean I'd the dial. I tried it early on and it destroyed the finish.
Edited by Geo
Mark re-attaches the balance to the plate prior to cleaning in his videos, and the manually cleans the jewels after. Whipping around a liquid bath seems more violent and sitting stationary in an ultrasonic cleaner so I'd assume it's safe.
Mmmmmmm, sloshing about may be Ok, I'm concerned that 22Mhz may mess with the hair spring..............
What about the Pallets?
I clean them all the time ultrasonically and have never had a problem. Edited by Geo
I have been collecting the tiny little Wilkin and Sons jam jars you get in some cafés, I can fit 3 in my ultrasonic cleaner and it means I can have a different fluid in each one if I wish.
The brass fine mesh balls are useful sometimes as well for the really small bits.
Like Bob and George I clean just about everything bar the dial and pointers.  The only thing I would say is dont use any solvent cleaner type substance that could dissolve the shellac/glue holding the jewels in place.
Since seeing Mark do it, I have started putting the balance back on the plate and it seems to be perfectly ok that way, it does not take long plus the plate gets a clean as well.
Cheers,
Vic
I have been using Mark,s method with my L&R cleaning machine (that also ultrasonic cleans in all three jars) and perfect results every time.
Pallets could be a problem if one of them is loose other than this scenario no problems.
As title really, all of the sites I normally use for my watchmaking, Cousinsuk, HSWalsh, and Gleave & Co, are all based in the UK, and all cannot ship the products I need to Finland due to being dangerous chemicals.
I am preparing my Elma Super Elite, watch parts cleaner machine, and need these following products...
L&R 111 Cleaning Solution
L&R #3 Rinsing Solution
15508778617_5ff71f4ba5.jpg2014-11-02_2210 by Micky.!, on Flickr
So as you can see, I am a little stuck on where to buy the above products from, and I don't know of anywhere in Finland that would possible sell them :(
Edited by SSTEEL
Hi Micky,
Have you tried some US suppliers? Is it the same situation as with UK?
This is unbelievable but I searched for "watchmakers supplies, Finland" and I got "Rio Grande" suppliers... not even supplying watch related products. Apparently Mexico has borders with your country!! :D
In any case, if you don't find one close to home, check our directory of suppliers, maybe there is one close enough that can send what you need, probably ground shipping. I believe it is going to be expensive at best. If you were to find one in Finland, tell Mark so he can add it to our directory.
Bob
Not cheap by any means, but no other option, so just purchased the L&R #3 and #111.  Both are the 3.8 litre bottles.
#3 €55.00
#111 €59
Shipping €20
Total €134
Edited by SSTEEL
Ouch, that is a bit pricey.
As this is a hobby with me I'm going to experiment with brewing my own. I picked up an old watch cleaning machine recently and l love to experiment. I will post how I get on whether good or bad.
I clean all my balances in the ultrasonic and have had no problems, however I have learnt to be a bit more careful with the Pallets as the cleaning solution can get a bit warm if used for an extended time period ( I personally can use it quite a lot in a one session) and sometimes Pallet jewels can come loose due to the shellac/ adhesive softening because of the increase in temperature within the cleaning solution...
Cleaned a watch this afternoon using my L&R machine and noticed the parts are a little bit sticky.  Thought it was my tweezes but i think the movement parts have a film of some sort on them. I have recently cleaned several clock parts in the L&R & wondering if there was just too much old oil etc & it has contaminated my cleaning solution.
I have been keeping count using two counts for clock movements & it totals 18 washes. Any suggestions guys.
I have been using Elma
I would not normally do clocks but if I did then I would use a separate jar of cleaner for the clock parts.
I used to work in a place where the clockies would take our used watch fluid to clean their watch parts (too dirty for us but clean enough for them). The exception was platform escapements which would not normally be a problem in the watch jar.
I have never used the Elma fluid but I have almost run out of my current stuff and was thinking of giving the Elma fluid a try. Apparently you use distilled water in the first rinse. Right now I use L&R watch rinse in the second and third jars. When the second jar gets dirty I will swap the third jar in it's place, discard the second jar's fluid and refresh it with new fluid - it becomes my new final rinse. Less waste this way.
    • Looked into this some more and I believe that some of the increase in rate is attributable to the drop in amplitude after 12 hours off wrist, from 300 to 275 degrees horizontal and some is due to the lower temperature (38 to 18 degrees). I can see that approx 3 to 4 seconds a day is attributable to each. I can be happy with that.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
