Rotary Ring Watch.
This is definitely the smallest watch I've worked on so far, a Rotary 9Kt gold ladies ring watch. I have not done a walkthrough as it is just a basic manual wind movement and these types have been well covered in the past.
post-124-0-90776300-1453415119_thumb.jpe
post-124-0-92866300-1453415172_thumb.jpe
It was not running when I received it, but luckily it just needed a good clean and oil and all was well. It is now holding +9 seconds per day which is more than good enough for a novelty watch.
Thats tiny!! How did you work on it?
It's really a simple movement Robero, it's is a bit fiddly because of the small size. It was so similar to this http://www.watchrepairtalk.com/topic/963-time-for-a-cocktail/?hl=audax#entry8339 that I didn't bother posting movement details. One thing I did have to do was reduce the size of my smallest screwdriver to make it fit some of the tiny screws.
Wow!  Talk about having to use fold-over magnifiers!  My fingers are so fat and jittery now that if I attempted to do anything inside a watch like that there'd be springs and sprockets flying everywhere!
Well done on even managing a basic service on the watch...I salute your patience!
Which reminds me...I have see little watches like this at the local flea markets powered by tiny quartz movements.  They can be had as rings or tiny pendants.  I bought one for my missus (who has a real thing about loving owls) in the shape of an owl.  To tell the time the wings are folded away revealing the watch face.
Pocket-font-b-Watch-b-font-Alloy-Cute-Op
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
