Serviced ETA 2763 having erratic rate and amplitude
I agree, game changer. I watched Alex's video as well. Another thing to consider is the adjustability of chair to bench and the head of the scope so that at max height is not above your eye level. I got the trinocular port for the camera but did not get a good enough camera and have not figured out how to run it though my laptop to make videos or just take stills through the scope, yet.
My Arnex pocket watch dial is toast but has a very nice Peseux 7050 in it. I have the same thought to one day build a wristwatch with this movement!
If only the shafts of the arbors were standardized to the smallest size arbor and the arbor cap/disk standardizedto the largest, then we would have a truly universal system. This would allow any handle to fit any size winder. But which manufacturer would be kind enough to do that? -
Did you try using the #7 winder with the #6 drum? I mix and match arbors/drums all the time.
When you think about it (as a watch addict) and how much you spend on a typical watch, anything less than about $15 is dirt cheap these days. I mean, that might honestly just be the tax you pay on a watch. You can barely even get a used part off of ebay delivered for that much. In fact, $15 seems like about what a new crystal or a used setting lever would cost to have delivered. I think anything under that would essentially be a, "Holy cow, I got this watch for nothing!" scenario.
