Hello again from the Philippines 🇵🇭
joelcarvajal
Hello, everyone!  Great to be back in this hobby.  I used to be active here until I decided to put this hobby aside.  Now, I’m rebuilding my tool set, eyeing some watches to repair/restore, and more importantly, visiting this good old forum where it all started for me.  Good to see I can still review some of my old posts.
Looking forward to enjoying and learning with you guys.
BTW, anyone from the Philippines here?
54 minutes ago, Waggy said:
Greetings and welcome back 🙂
What types of watches do you prefer, there is a great supplier of Seiko and Citizen in the Philippines that I use quite a lot on eBay, some great prices, some of them are in rough shape, but good for a challenge!
I had the best experience working on an Omega 751 from 1969.  So I’d say I prefer working on vintage Swiss watches.
The oldest watch I’ve worked on is an Elgin from 1948.  It was challenging but I just ended up relying on a donor movement.
But I’ve done a lot of Seiko’s since parts are very accessible here in the Philippines.
Yes, I also sourced some parts and watches from Ramon.  Very accommodating guy.
What got me back to this hobby is the 6139-6005 that I purchased supposedly for my 50th birthday.  It’s been 2 years and I have yet to start cleaning it. 😝  it’s been completely disassembled though and I’ve purchased some parts for it too.
I’m excited to work on it and share the experience with all of you.
  • 2 months later...
Hi Waggy - would you mind sharing the name of your supplier (or DM me)? I just stumbled on one with dozens of severely beat up old Seiko divers at prices I can't believe. But the dials and movements look correct and I'm tempted because I love a jalopy.
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
