As I start out disassembling my first movement (working ST36) I'm reading all I can to make sure I'm doing it correctly.  One piece of advice I didn't expect to read was to handle the movement the your dominant hand and use the tools with the other.  Can this be right?  Why would you do that if you want to be precise with screwdrivers and tweezers, etc?  I'm thinking I mis-read it...
OK, just wanted to make sure I wasn't crazy.  I can't even find that advise now but it sure looked like hooey.  Thanks guys.
Concurring with the people who hang out here is not necessarily an ironclad sanity check. 😉
I will wear finger cots on my right hand and use it to hold the movement while tools go in my left hand, but then again, I am left-handed. Do what feels most comfortable.
So you use your dominant hand for the tools.
36 minutes ago, watchweasol said:
Well that’s a load of Horse feathers and no mistake, try wiping your bum with the non dominant hand. Tsk,  tsk.
Didn't the Rolling Stones named an album about that.  Hehe.
Edited by RichardHarris123
Typo again.
For the most part. When oiling a cap stone i'll hold the tweezers in my right hand and the oiler in my left, but when setting hands, I'll position and steady the hand with tweezers in my left hand and press them on with my right. Bum wiping shall remain unanswered.
I do the opposite, but it brings up the point that one needs to develop some skill with the non-dominant hand.  Oiling cap jewels is a perfect case for that.
I like to hold the jewel with tweezers while oiler in dominant hand- yes?
Doesn't make much difference to me, not truly ambidextrous but close.
I think you naturally head that way, i have definitely noticed over the course of two years i am using my left hand much nore than i ever used to. I often hold a pair of tweezer in each hand at the same time. Position the part with my right pair, pop the screw in from the left, then switch the right hand for a driver. The more you practice the easier it becomes.
1 hour ago, tomh207 said:
I believe it’s like anything else we do, practice enables flexibility in approach. Like @RichardHarris123 I’m not truly ambidextrous but have fine motor skills with my non-dominant hand.
Tom
If you are not practicing as well then you are limiting yourself. I keep a small pot of screws and shock settings and spending 5 mins of twisting, twirling and releasing springs before i start to work on anything, kind of a warm up that stems from my weight training days.  If i dont work then maybe 10 mins just so i have at least done something.
Edited by Neverenoughwatches
My 14-year-old son who's quite an accomplished table tennis player regularly practises playing with his non-dominant hand. He says it has developed his overall skills quite a bit. On occasion, he has even used it as a weapon during competition to confuse the opponent.
Two-handedness, at least to some extent, is necessary when working on watches. It took me many months of practice to get somewhat confident using my non-dominant hand
4 hours ago, Nucejoe said:
Your brain tells you which hand to use.
Well, that's good to know! If it was some other body part telling us perhaps we'd use our left foot 😉
  • Haha 4
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
    • Yes, it looks much better, but at this point the main thing is to make the spring in one plain. so picture from side will show this better. Now it is seen that #1 bending is needed, which is normal.
