This is how I sharpen pegwood
1 hour ago, Waggy said:
Anyone tried steam to preclean the main plate and jewels? Something similar to the below? Maybe there is a smaller version or an attachment that would allow you to get into the nooks and crannies of the movement (pre-roving or avoiding anything with shellac of course).
Is it me or is that a little overkill. Might be at risk of flash rusting on anything ferrous.
10 hours ago, HectorLooi said:
And for those who think the waterpik is the answer to flossing, it isn't. The waterpik can only remove loose food particles. It can't remove plaque, it can't remove food particles pinched in the contact area of the teeth
I like to use mine to remove the floss that gets stuck between my teeth.  🙂
That could possibly work really well as long as the parts can take the heat. I sometimes use a fine-bristled toothbrush, washing up liquid, and (not too) hot water to clean larger parts and the result is truly stellar.
I had a bigger version steam cleaner in my lab. It was capable og 4 bar pressure. Never even considered using it to clean watch parts. The pressure is so great that things tend to fly into oblivion. I used it to clean dental micromotor rotors and stators. Also to clean wax out of plaster of Paris moulds during denture fabrication.
I don't think it has a useful application in horology.
Well, you're probably right about that! If it had, we would have heard about it already. After all, steam cleaners have been around since about the 1960s.
On 5/4/2023 at 3:04 PM, nickelsilver said:
I use a standard snap-off cutter, but use the extra sharp NT Black blades- really makes a difference on peg wood.
The other day I received my Japanese knife with extremely sharp blades, and even compared to my scalpel, even with a new blade, it is clearly sharper. I wouldn't say the difference is a revolution, but it's still very noticeable. I get associations with the infamous samurai swords 😎
It is easier, faster, and more accurate to carve into peg wood, especially the last sharpest part that you can shave with this knife, so from now on I will not use my scalpel for this purpose. Another advantage is that it is quick and easy to get a new sharp edge by just breaking off a piece of the knife blade, which is significantly easier than changing the entire blade of my scalpel, and significantly cheaper in the long run.
In addition, I took the opportunity to order a large pack of 50 knife blades, which I think will last for many years to come. Just like my scalpel blades, these blades are treated with a thin oil film to prevent rusting. I think it might be a good idea to remove this film with, for example, a piece of old Rodico so that you don't risk contaminating the peg wood and consequently the jewel bearing.
The only downside, however temporary, is getting used to the grip of the new knife. Carving into peg wood and making an extremely sharp tip is a bit of an art, so like other tools you need to get used to it and learn how to use the tool optimally.
I am really happy with these Japanese knife blades which I think will save a lot of time and frustration in the future. So, thanks again @nickelsilver for the tip!
Edited by VWatchie
Thanks for the review, I'll order one.
The Japanese seem good at making sharp blades. I have a good Japanese carving knife which is as sharp as a scalpel. I only sharpen it maybe once a year, and don't get it as sharp as I could, as it's so sharp, you can easily hurt yourself.
I just use either my pocket knife (I know.. poor choice but I keep it really sharp) or an exacto knife.  I do have one of those small snap off knives in the garage, but I have never tried using it for this.
Sorry but there is nothing special about Japanese blades.  Good quality blades from other countries are just as good and as sharp.
Nothing to be sorry about as these blades and the knife was very expensive compared to getting what's locally available. I had no idea! So nothing special about "extra sharp NT Black blades" then? How and when did you compare?
Fair point, I haven't compared.  My comment was that other countries produce steel to the same standard and thus should be able be sharpened to the same degree.  There's a lot of mythology about samurai blades, they weren't superior but the Japanese blacksmiths took low quality steel and forged it into good quality steel.
I don't know who makes the sharpest craft knife blades. I haven't been able to find any mention of tests. The sharpest blade would be flint - I might try some.
The first pic is a brand new craft knife blade. The edge is surprisingly uneven and rough.
The second pic is after a few minutes on a fine stone to polish the edge. It does cut better.
Obsidian?
You may be 100 per cent correct. I wouldn't know. Next time I see a similar knife when shopping I'll get it and compare them. Maybe it is just "hype".
Edited by VWatchie
For hundreds of years Japan made it an artform producing the sharpest edges from the finest folded steel. I have some Jap chisels that i use when working on quality hard timbers.  In 20 years some of them i have sharpened less than a half a dozen times and the edge is like nothing else i use. Bloody expensive though. Not used to sharpen pegwood , i find a fair quality craft knife blade does the job sharpened on a 3000 grit sintered ruby stone . Anything sharper then a Washita or Arkansas or finer still would be on my old Tam O Shanter stone, the grit supposedly can be as fine as 10,000. Probably pointless on a cheap knife blade, the steel wiĺl only sharpen as far as its grain will allow. I guess these Japanese blades are really thin, the carbon content also on Jap steel is generally higher than anyone elses.
I didn't like to show my newbie ignorance, but there are some parallels I have seen with my other (woodworking) hobby. Most commercially produced blades have rough edges that can be improved by a few passes on a leather strop +/- a honing compound eg Autosol. But, for me, it's the technique of sharpening the peg wood that makes the biggest difference. I use a piece of hardwood faced ply as a cutting surface and after the initial cut, support the cut surface for subsequent cuts. Seems to keep the finest tips more consistently, but sadly it doesn't make them last any longer in use! I use Swan Morton scalpels with disposable blades (and yes, even these are improved when you get your strop on).
That's very interesting. I have been sharpening my pegwood holding the knife in my dominant hand and the pegwood in my other hand without any support. That method is very exhausting so I will definitely try to use your method. Thanks for the tip!
Anyway, having zero experience with crafts, what exactly is "hardwood faced ply"? I searched eBay for that phrase  but I am really not sure. Perhaps you can provide a link to an example?
Edited by VWatchie
I would interpret it to mean: a plywood constructed with (at minimum) a layer of hardwood on the outside face.
I believe most plywood is sheets of fir laminates.
Some plywood is laminated with all hardwood sheets while some may have a particularly figured sheet of decorative hardwood on the outside face.
I work in oak primarily and had some offcuts of this https://www.howarth-timber.co.uk/plywood-white-oak-veneered-single-side-2440-x-1220mm/. Sanded off at the edges and only needs to be 10cm by 10cm for my purposes. I had 6 ply, but for this, 3 ply would do. Ive found that for me, by supporting the last cut, subsequent ones are more accurate and less likely to result in tip snappage.
    • Another question if I may. When you guys buy watch lots are you buying a mix of mechanical and quartz as well? Most of the job lots I am finding (all overseas) are a mix. If they are all mechanical, it is generally just movements with no cases. I am not at the point where I can identify movements by just viewing them so I'm not inclined to buy a bunch of stuff which will just end up lying around. Is anyone able to successfully move any of the watches they save on to someone else? I can't see a viable market in Australia for refurbished watches. Most people I have seen at work only have a watch if it counts their steps, answers their phone and makes the coffee. I'll admit it, I have a super cheap smartwatch on my wrist. Will I buy another one when it quits? Doubt it. I don't know if I would even bother with a pedometer. Heart rate? And do what with all the data? Blood pressure? Never been right since I got the watch. Sleep? If I can't work out that I'm not getting enough, I need to have a serious talk with myself. I think I'll go back to my Seiko and just make myself stay active.
    • I suppose this fits "best" in this forum 😃 Im looking for some wall 'art' that doubles as a reference. Specifically Id like to find an ETA 28xx or Sellita exploded movement view. 2824/2836 would be ideal. Have any of you seen/found such a thing - there seem to be a lot of these for specialized movements, and none of them ready to print or to be had as a poster. Why help is appreciated.
    • The diameter is that of the ring - afaik, will have to look it up. “Wiggle room“ doesn‘t matter as long as the spring length is in the ball park.  Essential sizes of a mainspring are thickness, width and length. Diameter is just a hint if you can push into the barrel directly or will need a winder, it is no property of the spring. Frank
    • Hi @Zendoc, I guess you're like me and you don't have a mainspring winder.  I searched GR mainspring for the AS 1686 mainspring and I now understand your dilemma. The exact one is discontinued. To answer you question more directly, I see two good alternatives for you: a) GR4485 with 1.60 x .10 x 280 x 8.5 ( I guess this one is the one you found): https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/GR4485 OR b) GR4477 with 1.60 x .095 x 320 x 9. https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/gr4477   As you know, the the AS 1686 spring is supposed to be 1.60 x .10 x 300 x 9. - both of the above will fit and you'll manage to insert them from the retention ring without need for a mainspring winder (provided you know how to do it). - GR4485 will give you more power (=higher amplitude), but less power reserve (due to shorter length) than the original. - GR4477 will give you the same power reserve as the original. However, a bit less power.   Personally, I'd take GR4477 for two reasons: 1. Well, the power reserve is better. 2. With modern lubricants and modern mainspring metal alloys, you tend to get a higher amplitude anyways. You'd maybe even end up with too much amplitude (knocking) if you go with the original size and use thin synthetic oils-- see discussion here: https://www.watchrepairtalk.com/topic/10580-omega-calt17-help/#comment-248101
