Barrel-Spring help
hello will this watch case be sufficient, i was thinking i could use this watches case as a replacement. will this idea of mine of finding donor watches work? if anyone could please link some it will be really helpful https://www.ebay.com/itm/133161104092
I recently had exactly the same problem on an ETA 2773. Cousins don't stock the reversers any more, but I found another cleaning cycle made things much better. I had been using my own mix of lubricant - 9010/naphtha, but now I've switched to Lubetta I'm getting more consistent results
I think you have a typo - should be $500 not $1500 for a cal 10xx watch in good condition 🤣 If you look at @JohnR725's link to Julesborel, you can find which parts are common to other movements, then search on ebay. You can pick up parts or scrap movements for these 10xx series fairly cheaply - I did, I have a couple of 1012's
Photos of the case, can you remember what the dial looked like? A few variations for the time period.
