Is there an etachron stud twisting tool that fits seiko studs?
Its ok blueharp the pictures you provided earlier of the 3 keyless components, the setting lever, the setting lever spring and the yoke plus the brass cover plate should be enough. If they are not listed anywhere then you are relying on any lettering on the movement or someone that just knows the movement from experience. -
Thanks jon, that would be my only option but i have bigger problems now with this one -
By nickelsilver · Posted
I have only been in one head with the lever closer, and that was a long time ago, but I don't recall anything attached there. Does it function? I have an old ratty head I pulled apart to give an exploded view, with the tools necessary to take it apart. You can see the large spacer, then the small inner spacer I made in the other pics (standing up with the large one, and on the spindle). -
I tend to replace them with friction fitted jewels, unless the client wants to keep the originality of the movement, but then they pay more for that luxury.
