Replace jewel in pallet fork bridge
I think I would use a spray on oil for springs.
By LittleWatchShop · Posted
Sure, but that means you remove the crown, add the extender, install the crown...only while on the bench. Is that worth the effort? -
I had to squeeze the insert in which is ok. The movement size is slightly reduced. One negative...you cannot wind or set the watch while in this holder.
