I have a Timex Dynabeat that requires some work. I've had the watch for a bit and the watch has been acting up lately.
It developed a loud ticking noise when the dial is face up. When it is placed face down the noise goes away. Plus it will stop randomly from time to time. Although a shake will get it running again.
I've taken the watch to a couple of watchmakers near my area. They all said it needs to be serviced but they didn't want to work on it.
What are my options as far as getting it serviced? If anyone can point me to someone who can help me out that would be great.
Thank you.
Wow! A telephone dial Dynabeat. I've never seen one of those.
Dynabeats are a strange beast. They were pre-quartz era, battery powered mechanical balance watch. Not many watchmakers will take on such a repair.
So, what do you wish to do on this forum? Do you wish to learn how to service this Dynabeat yourself or are you looking for someone to service it for you?
If you're not yet comfortable rebuilding your own movement, replacement movements might be available for negotiation.  Either way someone here may be able to help.
Shane
Shane
I don't have the experience to try and work on these. My best bet is to find someone to work on it or finding a replacement movement.
What causes the loud ticking noise and how do you repair it?
Regds
I forgot to quote you first.
Usually loud ticking (in this type of movement) is from to much end shake on the balance wheel.  You adjust it by tightening one of the screws holding down the balance bridge just a bit more than feels comfortable (checking end shake as you go).  It may seem crude not to have just bottomed the screw out and adjust end shake some other way but it is very clever, it works like a belleville spring washer and holds the screw tight against the threads in one direction and doesn't let it vibrate loose.  As you tighten that screw and it warps the plate and reduces end shake.
Shane
1447789573_20200417_145318.jpg.6ce95c18d12f107ef3ae04c5abdb679f2.thumb.jpg.da8e1b5e09b546ab4a721d8859167930.jpg
Edited by Shane
Place 10 or so Timex electrics on a flat table top and you will have the sound of a stampede.   This movements are just loud....
 "find a donor"?  If you do find one and it is used how do you know it is any better?  Even if you find an NOS it has been in storage for decades and will require a service and than installation.  Sorry but with vintage Timex this option has limitations.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
    • Could you fit a sapphire crystal? My 'daily wearer' Breitling Aerospace is 22 years old and there isn't a mark on the sapphire crystal.
    • Oh that's neat. I typically use a thin strap of rodico laid over the pallet fork to affix it to the upper plate but it can be hard to retrieve sometimes. And as I did more research, I may have just found your own earlier explanation: https://learntimeonline.com/forums/topic/potence-clip-for-full-plate-p-ws/
