Relume Watch Hands.
This is a personal view only.
If it is lume on the markers and paint on the numbers, I would match the hands to the markers.
If it is lume on the numbers I would match the hands to the numbers, which I think would look better anyway.
For a large jar of quality lume + thinners try Ranfft's material:
http://www.ranfft.de/cgi-bin/bidfun.cgi?10&ranfft&b7&1usem&1456959601
or for smaller jars:
http://www.ranfft.de/cgi-bin/bidfun.cgi?10&ranfft&b6&1usem&1456959602
Not low-cost but, as he says: optimized for use.
Useful notes on the application of lume - similar to Mark's
I only really need the thinner, as I've mixed up a collection of pigments for matching the hands with what's already on the dial.
I've tried lighter fluid, acetone, turpentine and acrylic paint thinner.
And none of it works. Just doesn't mix in and separates with the binder.
I've found that the bought lacquers can sometimes harden to an extent that you can't apply them if your doing a dial and hands at the same time, you just some run out of time.
It's also a pain then to mix another batch with the exact same consistency as the last so it matches.
A tip that works for me, I use UV curing clear nail polish as my lacquer for powdered lume's, it's fairly inexpensive, doesn't harden as you use it and of course you can cure it under uv light I less the 20 secs. If you are luming 12 indices on a dial it's nice to add or remove droplets with an oiler, this method allows you to get all 12 nice and equal,
Top tip, don't do this in daylight
Are you able to use a thinner with the UV nail polish or is it a case of once it's set it's set?
What kind of uv lamp do you use? And where do you buy the clear coat nailpolish?
Hi guys,
I've been following this threads with interest and by my recent experience with luminova from ofrei, I believe it just has to be the right mixture (consistency). I was able to prepare enough for a bunch of different Seiko hands. My way:
1.- dip watch hands in acetone
2.- clean thoroughly (acetone will have dissolved the old lume)
3.- If needed, sand lightly
4.- prepare the mixture: lume powder, varnish and thinner. Texture is kind of flowing almost liquid but not quite. Mix thoroughly.
5.- Apply with oiler (usually the yellow one but it depends)
Since you prepare the mixture in the very last minute -- having everything else ready beforehand -- chances are your lume never dries out while you are working it...also, prepare a reasonable amount: too little dries faster, too much is a waste.
I hope this helps,
Cheers,
Bob
PS. When applying lume to watch hands, it gives me an idea I'm making bubbles with this round thing we used as a kid....maybe this mind picture helps to realize how little lume is really needed for each hand...and how important is to have it right the first time!
For the UV lamp, just search eBay, they range from £10 to £35. I use CND shellac UV base coat, but I guess any clear uv curable nail shellac would do.
When just doing hands, normal luming method is fine and does work well, but when doing indices at the same time and out of the same mix I always seem to run out of time, as I'm applying the lume the viscosity changes as it hardens slightly
Then I have to do another mix and it's never the same in terms of viscosity and lume powder content and therefore doesnt match.
You only need seconds to cure this product under a uv lamp, mine is a 35 watt unit probably too strong a light as I don't even have to put the dial and hands directly under it, just near it is enough to cure them.
Thanks to Mark for the Vid and everyone else for the additional info.
I have been able to do a half decent job on my first re-lume and I am well pleased.
First I researched for colour and got the lume that I hoped would be close to a match. It changed colour on drying but that was to my advantage, I would love to claim skill but it was pure luck. It has some luminescence but I don't really care about that part.
This is the before image it looks more orange in this photo than it actually is.
Got the stuff together
Hands have been cleaned with soap solution in the ultrasonic and all the old lume came off, then given a good bath in isopropanol to get rid of any soap or grease.post-197-0-48429700-1453039150_thumb.jpepost-197-0-07978400-1453039241_thumb.jpe
Following Marks advice, it seems to go on quite thick but on drying the thickness disappears, I ended up giving it two coats as it was a bit translucent with just the one
post-197-0-90100900-1453039470_thumb.jpe
post-197-0-62018900-1453039521_thumb.jpe
post-197-0-57254600-1453039590_thumb.jpe
It even glows a bit
post-197-0-69591800-1453039646_thumb.jpe
Last pic I have rested the hands on the dial which as yet is uncleaned, probably will just be given a gentle wipe down with cotton buds and mild fairy liquid solution.
Not too shabby, and I would never even have tried it if it was not for help given on this forum - Thanks to allpost-197-0-17299600-1453039839_thumb.jpe
post-197-0-50551000-1453039984_thumb.jpe
Thank you very much for the tutorial, I am learning quite a bit from everyone. I wish you all the very best.
and special thanks to Mark for all the hard work and effort on your videos and tutorials.
Thank you
Omar, raleigh USA
  • 3 months later...
Here is how i do the relume :) Since i am hobby watchmaker i am using cheap chinese powders. It turned out that they are really good for the price! There are three types that are white in daylight each with different properties (the colored ones are from this 3 type with some paint added, lol). The night green one has the highest initial brightness which goes pale quickly. The turquoise has low initial brightness and loosing it as fast as the green one. And the deep blue has lowest initial brightness but is as bright as the green one in half an hour and much brighter after a night. You can see all of them glowing after a night and even after a day in complete darkness if Your eyes got used to it.
Particle size is really important! The bigger the brighter. But bigger ones are harder to apply and looking ugly on the watch. So we have to make a compromise here. There are pigments sold in ~ 1mm particles which need to be grinded and sieved. Used this sieves:
http://www.ebay.com/itm/T304-Stainless-Steel-Co**BLEEP**-Dense-Gauze-Woven-Mesh-5-to-500-width-3-to-20-VA-/181505011630?var=&hash=item2a428aafae:m:mr9ZSZ3z9I76O9J31WG9ejA
Between 0.03 and 0.07 mm is perfect. It is important to leave out the finest batch since it will fade the lume.
The three whites here have a good particle size:
http://www.ebay.com/itm/3-Super-Bright-Glow-In-The-Dark-Powder-Luminous-Pigment-Strontium-Aluminate-10g-/222043965311?hash=item33b2da077f:g:PfEAAOSwjVVVr63b
Tried acrylic (Tamyia x22), nail polish and UV nail polish up to now. Acrylic is soft if hardened and may be soluble in water and can adsorb it even if cured. You have to exclude water since strontium-aluminate will fade in presence of it. Simple nail polish is excellent, i dilute it with semi-polar solvents like "epamine" solvent (mix of aromatics and alcohols). In particular, You have to use those with high boiling point. Check the composition; look for xylene and n- or iso-butyl alcohol. If toluene and/or iso-propyl alcohol is written on the label then dont buy, it will evaporate quickly. These solvents are also OK for the UV gel. Just deposit the mix on the surface and let it dry, and expose to UV thereafter.
Mix the prepared paint every time before taking from it, since the big particles will settle at the bottom and You wont get consistent coating on the different indices or hands.
Using dichloromethane for removing the old lume quickly. Using ear cotton buds dipped in this solvent if the hands are painted to scrub down the old lume carefully not to touch the upper side of the hands.
Just sanding down the excess if to thick layer is applied with sandpaper after curing. Usually leave 2 days for acrylic and simple nail polish to cure perfectly. The acrylic is much softer.
Here is my every day watch with the green on the dial and hands and deep blue on the bezel.
And some comparison of the powders. You can compare the lume brightness dependence on the particle size looking at the small vials. First batch is 0.075-0.106 mm and the smallest batch in the middle of the picture (<0.032mm). The blue ones on the right are on their original grain size:lume comparison.jpg
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
